C5 X7 power steering pipes
citroenc5mad
Hi guys. I'm in desperate search for both of the pipes.
I was hoping someone may know what part numbers I need to hopefully cross reference them with other psa/aftermarket pipes.
I've contacted every car breaker on ebay, I've tried my local breakers.
The garage has contacted citroen with no joy for them and it's getting frustrating searching all hours and getting no where with this part.
Also does anyone know if a c4 would be compatible or even a Peugeot 508.
Thanks for the help
Thanks for the help
- x 6956
Re: C5 X7 power steering pipes
We need your VIN as you have not put your model, year or specification in your profile, so you are not going to get much help.
No, they are unique I'm afraid - these X7 pipes are unique to the X7, but I will double check once you have supplied the VIN so I know exactly what system you have as there are multiple pipes.
citroenc5mad
I can pm you the reg of it, if that helps and also of a second car I'm hoping the pipes will fit from. If you could cross reference them for me that would be great
- x 6956
I'll need the VINs (they will be automatically hidden when you post - so only staff can see them).
- x 3566
There have to be companies out there capable of making rigid or semi rigid PS pipes. The only critical part of the pipes are the ends as these have to be correctly swaged to the right shape and size. There must be suppliers to the specialist classic car restorers who have the ability to make these pipes. Anyone know of any ?
- x 5671
I imagine that Pirtek would be capable.
citroenc5mad
Hi Marc.
My cars currently in the garage so dknt have the vin and also the car at the breakers and they want pass me over the vin number either so I'm kinda neckard then I assume??
If they won't cross reference I will be looking at getting some made up for me.
Steve Walsh
- x 515
If they want to sell the parts, It would be in their interest to supply VIN number
citroenc5mad
My VIN VF7**************[VIN obfuscated, can be read by forum staff]
donner VIN VF7**************[VIN obfuscated, can be read by forum staff]
Sorry it wasn't sooner but just finished work
Reason: Corrected Second VIN - 1 Character missing
- x 6956
Hi
Ok, no worries.
I have checked and the Donor vehicle, which is a 2.0 HDi DW10BTED4 and the pipes are different with different part numbers to your 1.6 HDi 110.
There is a physical difference in both shape and the connections it seems, so sorry to disappoint you.
Ok, no worries.
citroenc5mad
Hi Marc.
Thanks for the reply I suppose it has to be a 1.6hdi I need as a donor then as I assume its because mine doesn't have hydroactive suspension so the pipes are different in that aspect.
- x 6956
Actually, no, as both cars are non-hydractive and have Metal Suspension.
The actual steering racks are different. The donor car has a 180 rack travel and yours has a 184, plus the PS pumps are different, so it is not down to the suspension. I hope that clarifies some differences for you.
citroenc5mad
Hi Marc.
Thanks for the clarification, as I assumed that the donor car was hydroactive as thats what the bloke told me so I've no idea tbh but if the van is saying it ain't then it can't be can it???
- x 6956
Correct the VIN identifies it as a 2.0 HDI with Metallic suspension, an early 2008 model.
citroenc5mad
Could this vin get cross referenced to my vin please guys.
