HI Folks
I'm after a wiring diagram for a Citroen Despatch 2.0 hdi 2013
Having troubles with a new / secondhand engine that we have fitted. The old engine seized due to an oil pump failure.
New engine has problems with the injector harness.
Thanks in advance
Matt
Wiring Diagram Despatch 2.0hdi 2013
Re: Wiring Diagram Despatch 2.0hdi 2013
What is your RP number? this can be found on the bottom of the tyre pressure sticker.
- Attachments
11475U9
Matt
Matt
This should hopefully tie up with what you have.
That's great, many thanks wheeler
