Part numbers request 2010 1.6hdi 16v
moizeau
- x 429
Could someone supply me the OEM numbers for the clutch kit for my Dispatch please along with driveshaft and gearbox oil seals?
Apparently there is also a sleeve that that release bearing slides on and this wears?
If anyone has a 'how to' that would be great also, the BOL's is awful on this.
Cheers
Cheers
Pete
OnlineRichardW
- x 1485
OnlineRichardW
- x 1485
Re: Part numbers request 2010 1.6hdi 16v
Some where between these 2 you should be able to work out what is required.
I rather suspect that hefting the box in and out as not as easy as he makes it look!!!
- x 6956
I have the VIN Richard. VF7**************[VIN obfuscated, can be read by forum staff]
There's no 'kit' showing for this van only separate parts.
The Clutch mechanism is 2004AV
The Clutch Plate is 2055HT
Item (3) is 1611266780
Item (4) Clutch fork is 211766
Any other bits let us know.
Left New OEM Driveshaft is 3272XL
Left Exchange is 3272XN
Right OEM is 3273YF
Right Exchange is 3273YG
Right OEM is 3273YF
OnlineRichardW
- x 1485
Clutch kit is item 8 Marc...
08
2052 66
RP 16 112 692 80
01
01
CLUTCH KIT
An entirely sensible [NOT] £375 from Citroen. At least it looks like a solid flywheel!!
The release bearing guide sleeve / seal is item 5 above, very cheap, not worth not replacing.
Driveshaft seals 9 and 10 in here
08
2052 66
RP 16 112 692 80
01
01
CLUTCH KIT
- x 6956
How did I miss that
moizeau
- x 429
Thank you very much chaps, very much appreciated.
Pete
moizeau
- x 429
So if I order the clutch kit, guide and seal, and a driveshaft seal for both sides I should have a bases covered or am I missing something?
Cheers
Cheers
Pete
moizeau
- x 429
Sorry, one more question. Both the kits for Valeo and LUK here show all the correct numbers but different diameters and different gearboxes? Was just about to hit the buy button, currently paused...
https://www.piecesauto24.com/rechercher?keyword=205266
Pete
- x 1056
Gear oil & a new copper washer for the drain plug?moizeau wrote: 06 Apr 2021, 16:01 So if I order the clutch kit, guide and seal, and a driveshaft seal for both sides I should have a bases covered or am I missing something?
Cheers
moizeau
- x 429
Cheers Wheeler, knew I'd miss something soft.
Just checked the BOL's and it reckons I have the BE4/5 box so looks like the Valeo assy.
Anyone know the size of the washer and is any SAE 75w-80w good to go and there is 1.7 litres? Is this measured or level plugged?
Cheers
Cheers
Pete
moizeau
- x 429
Could someone confirm this part number please?
3272NK it's a CV joint.
I tried to dismantle the front today after borrowing a friends pit and the LHS driveshaft nut was a tight as...It eventually undid whilst stripping it's thread to the point where it won't finish coming off and won't screw back in either. I couldn't leave it over my mates pit for the unforeseen so have bought it back home. It's awaiting the grinder now. At least I found out that I can move up through the gears without a clutch to save wrecking the bearing more than necessary.
https://www.piecesauto24.com/ridex/13648090
Cheers
Cheers
Pete
- x 1751
Gear oil of 75W-80 is fine, but needs to be GL-4 spec (not 5 or 4/5).
2L will be sufficient.
moizeau
- x 429
Thanks Chris
Pete
- x 6956
If this is for the Dispatch (Rich's old one) then it is a Driveshaft, but not the right part listed....moizeau wrote: 15 Apr 2021, 16:16 Could someone confirm this part number please?
Cheers
3272XL - New OEM Left
3272XN - Exchange Left
3273YF - New OEM Right
3273YG - Exchange Right
