Hello
Im struggling.
I have fault code P0303 - Injector number 3 stuck closed
I have read with Autocom and SnapOn. Same fault code.
I did change the injector, with a used one.
Same fault code still.
The cylinder 3 does not fire at all. I can pull the connector to the injector and nothing happens. Pulling the rest of the connectors - will kill the engine.
I have checked the injectors with oscilloscope (SnapOn). And alla injectors give the same pattern.
I have also checked the wiring between ECU and injectors - all OK!
Any ideas?
Is it time to buy Lexia? We have bought our selves a 2011 C5 with problems with gear change, so would be good to have it.
Boxer II Runs on 3 cylinder fault code P0303
Orchid70
- (Donor 2021)
- x 6
- x 1938
Re: Boxer II Runs on 3 cylinder fault code P0303
Which end of the engine did you count from? PSA engines count from the gearbox end so if you counted from the auxiliary belt end you will have changed the wrong one!
- x 1451
I think that P0303 is detected by the engine ECU monitoring the crank position sensor and determining that cylinder 3 is producing no power.
On a Diesel, this could be lack of fuel, or it could be a lack of compression. Are you able to perform a compression test? or even crank the engine with the injectors disconnected and listen for even cranking on all 4 cylinders?
Orchid70
- (Donor 2021)
- x 6
Thank you
I do know that the cylinders are counted from the flywheel on PSA - but see this video:
I do not have copression tester for Diesel. So will have to try to figure it out without one.
Will get back on that later.
- x 1451
Maybe you can use your oscilloscope to monitor the battery voltage when cranking, the dip in voltage as each cylinder hits compression should be equal.
Orchid70
- (Donor 2021)
- x 6
Thank you Xantia_v6!
I have ordered Lexia 3 from UK today and its already left to the Post Office!! Im going to need it for the gear change problems on our new C5.... but thats an other story.
Thats a very nice tip! Im not too familiar with the oscilloscope - learning =)
I took a footage of cranking the engine - guess I dont even need the oscilloscope (God only knows, why we didnt think of doing this before..... hubby is the old time mechanic and Im learning....):
- x 1451
That cranking sounds a bit lumpy.
Orchid70
- (Donor 2021)
- x 6
Found the firing order in my old Autodata:
Kylesagar
Hi, I have a 57 plate Peugeot boxer with almost the exact same fault & problem as you. Mine is on cylinder one though can unplug & wont change running of engine. Have checked plug with a light probe & behaves the same as the other plugs. 4x new injectors then swapped number one for an original to see if it was an injector but still have the same issue. I’m thinking it’s a PCM problem. I have just changed the block for a reconditioned lump from transit tech. Didn’t have this problem when it came in. .
Orchid70
- (Donor 2021)
- x 6
HiKylesagar wrote: 14 Jan 2022, 08:11 Hi, I have a 57 plate Peugeot boxer with almost the exact same fault & problem as you. Mine is on cylinder one though can unplug & wont change running of engine. Have checked plug with a light probe & behaves the same as the other plugs. 4x new injectors then swapped number one for an original to see if it was an injector but still have the same issue. I’m thinking it’s a PCM problem. I have just changed the block for a reconditioned lump from transit tech. Didn’t have this problem when it came in. .![]()
This car is still "under work". The owner took it home to leave it to his garage in Denmark (we are in Sweden). But nothing have happened yet.
He is planning on swapping the whole engine.
So, you have changed the block? Not the cylinder head? Did you do a compression test?
And the problem still remains?
And thats why you think it is a engine ECU thing?
We would be thankfull if you would tell us how you eventually fix the problem.
Kylesagar
Hi, so yes engine had a bearing failed (full of metal shavings in oil/filter housing & knocking very badly) now all back together with a reconditioned block. I have cylinder 1 signal injector locked closed. Have been doing wiring tests today nothing so far. Try me again in a week or so. Another couple of tests tomorrow electrically. Will then compression test if nothing doing,
Cheers
Cheers
Maraspower
- New User
Hello, i have the same problem, can you tell me what was in your case?
