C5 X7 - Removing Dash After Airbag Triggering
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: C5 X7 - Removing Dash After Airbag Triggering
No worries - best of luck with it.
- My Cars: Citroen C5 1.6 110cv 2008
Re: airbags acionados- não consigo tirar tablier
not wanting to abuse but while i took the front of my car for a little crash i saw this disconnected tube is normal?
Reason: Removed Quote
- Donor 2023
- Lexia Available: Yes
- My Cars: C5 X7 2009 2.0 HDI VF7**************[VIN obfuscated, can be read by forum staff]
C4 2010 2.0 HDi Exclusive VF7**************[VIN obfuscated, can be read by forum staff] - x 378
It looks like a drain tube for maybe the fuel filter to allow water to be drained from it ?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
It's more likely to be the Air Conditioning drain pipe. It is normal to be left loose so the water can drain out. That's why you can sometimes see a pool of water under the car on a hot day when the AC has been on.
oh yes there is logic ty bro you ar the Best!GiveMeABreak wrote: ↑28 Mar 2021, 15:13 It's more likely to be the Air Conditioning drain pipe. It is normal to be left loose so the water can drain out. That's why you can sometimes see a pool of water under the car on a hot day when the AC has been on.
one last question I just need to remove the center console as shown in the picture ... do you think you can help me again? it's so stuck and I need to let it go for the tablie to come out
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Hang on, I'll put that up for you shortly.
Ty man you are awesome
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
C5 X7 Centre Console Removal (Manual Gear Box)
Move the front seats as far back as possible.
Refitting
Proceed in the reverse order to removal.
Tighten:
The bolts (6), (14) to 0,4 ± 0,25 daN.m
The bolts (8), (16) to 0,5 ± 0,25 daN.m
Unclip the gear lever gaiter ( 1) ( as "a" ) using trim removal tools. Disengage the gear lever (1) gaiter . | Remove:
Remove the glove box (2). |
Unclip: The handbrake gaiter (3) ( as "c" ) using trim removal tools. Remove: The handbrake gaiter (3) (At "d" ). | Unclip: The facia of the central console (4) ( as "e" ) using trim removal tools. Detach: The facia of the central console (4). |
Disconnect the connector ( as "f" ). Remove: The facia of the central console (4). | Remove the bolts (6) (Central console (5) ). |
Slide the front seats as forward as possible. Electric seats:
Remove the blanking piece (7) (Central console (5) ) (Symmetrical operation ). | Remove bolts (8) (Central console (5) ) (Symmetrical operation ). |
Unclip: The stiffener (9) (Central console (/) ) ( as "h" ) using trim removal tools. Remove the stiffener (9) (Central console (/) ). | Open the central armrest. Unclip the diagnostic socket ( as "l" ). Detach:
Remove the central console (5). |
Refitting
Tighten:
don't know how to thank you big thank you saved my day
collision and airbags deployed
good afternoon everyone, thanks a lot for the help ... i have a citroen c5 x7 1.6hdi 2008 i had a little crash and the airbags (knee, dashboard and steering wheel) were activated ... so i started to replace everything that broke ... a my question is do i have to replace the front airbag sensor? where is it located? another question is before inserting the new airbags and replacing the airbag module do I have any procedure to do? accept tips and advice thank you good week everyone
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I have merged your post with the existing topic, so as not to duplicate answers.
I think I already mentioned that you must replace the Airbag control module after any triggering of the safety systems. It is located in the central console.
It is shown as item (6) in the third picture of my post here:
viewtopic.php?p=680430#p680430
Obviously you must have the battery disconnected and wait for 5 minutes or so before removing.
There is no coding needed for the new one, as long as there are no issues once everything is connected back up. Remember you will need new seatbelt pre-tensioner units too most likely.
yes I understand ... can you tell me has a collision sensor and where is it or if this model works only with the module?
