C5 2.2 Hdi - fault after fitting new Injectors
KevMayer
Hi,
I recently fitted some refurbished diesel injectors to my 2.2 HDI in my C5.
The engine started and ticked over nicely, but, when I took it for a drive, as soon as I pressed the accelerator pedal to move off there was a bang followed by a loud ticking/banging noise and lots of white smoke (I assume unburned fuel).
I've taken the 'new' injectors out and removed the inlet manifold. All the rockers look ok.
Of the 4 injectors 3 were dry and the 2nd from left was very wet.
Does anyone have any experience of this or any ideas what might be the problem?
Cheers, Kev
- x 6955
Re: C5 2.2 Hdi - fault after fitting new Injectors
Apart from the specific injector issue you mentioned, were these the correct injectors and were they coded to the engine ECU?
KevMayer
Hi,
Yes, they were carefully selected and are definately the correct injectors.
Cheers, Kev
- x 1934
Were they coded in to the engine?
KevMayer
Hi,
The injectors don't need to be coded on this engine.
Cheers, Kev
KevMayer
The engine is a 2002 4HX(DW12TED4) with a BOSCH injection system (apart from a Siemens fuel filter).
Cheers, Kev
- x 6955
No, but the injector mileage counter may need resetting in the injection ECU depending on the mileage if 3-4 injectors have been replaced. From 0 to 37.5k miles the counter needs setting to 0 KMs. From 37.5K to 50k miles the counter needs resetting to 80k Kilometers If the mileage is greater than 50k miles, then take no action on this front. Ditto for the MAF.
If the Engine ECU is changed then the Injector class must be checked.
KevMayer
Hi, and thanks for the replies so far. It's great to know there's lot's of knowledge and experience amongst the guys on this forum.
The engine has done just over 170,000 miles and all 4 injectors were replaced.
A friend of mine used to be a mechanic and, when I told him what had happened he immediately said he'd seen something like this before and in that case it turned out to be a miss placed seal in the top of one of the injectors. This blocked the fuel return to the 'leak off' pipes and resulted in the injector overfuelling into the cylinder. In his example, Rockers were broken on the affected cylinder.
So, I've checked my rockers and they all look good.
I'm next planning to remove the sump to see if there's damage to the big ends etc.
The banging when it happened was loud and sounded just like when I was a boy with my grandad when a big end bearing went on his mark 1 Cortina estate ( in about 1968).
Cheers, Kev
KevMayer
Hi, I've looked at some Youtube videos of Injector Knock or Diesel Knock and I'm suspecting this is the problem I have.
I've not had chance to do any more to my C5 yet. So, in the previous reply when you say Injector Mileage Counter do you mean how many miles an injector has been used for or how many miles the car has done.
The mileage for the car is 170,000 miles, but, the newly refurb'd injectors won't have done any miles yet. So do I reset the counter to zero?
I have a Lexia 3 so can access the required parameters.
Cheers, Kev
KevMayer
I got a second hand injector off ebay and fitted it in cylinder 3, where the wet injector was found. The engine started and ticked over smoothly, so, no engine damage.
Looks like my fear that some terrible damage had been caused is not the case. It was a case of diesel knock.
I'm going to return the 'wet' injector for a replacement.
Cheers, Kev
KevMayer
Does anyone know if my 2.2 Hdi has a knock sensor?
It's a 2002 engine.
It's a 2002 engine.
Cheers, Kev
- x 1056
Cant think ive ever seen one on this DW12 engine.
- x 1240
Slightly off the subject. I had a Commer 15 cwt van in the '60s with a Perkins 4/99 engine, it was only a couple of years old, one of the newest vehicles I have had. One day it started knocking as though a big end had failed, my heart sank until I changed the injectors, noise gone, one injector was stuck partially open.
KevMayer
I got a replacement injector from the ebay seller and fitted it, but, when I took my C5 for a run it started to bang again as i accelerated.
So, I'm still not up and running and I'm fishing around for what to do next.
Looking in Lexia, there's a need to tell the ECU what injector class it has. The options are 1, 2 or 3.
It's set to 2. But, what are the chances that the rebuilt injectors correspond with class 2.
I'm wondering if I need to change this value to class 3.. or maybe 1.
Is anyone familiar with this classification system
Cheers, Kev
KevMayer
Now fixed.
The banging was pre-ignition because my EGR had been blanked. When I removed the EGR blank the pre-ignition (banging) went away.
Once I could drive without the severe banging noises, I was getting a lot of thick white smoke once the engine began to warm up. This was due to an air flow problem. One of the vacuum-controlled butterfly valves had gone faulty and as the two valves changed over I ended up with both valves closed and no air flow (2 vacuum butterflies - intercooled air inlet or heated air inlet).
I disabled the faulty vacuum valve to default as permanently open and now the engine runs well.
Cheers, Kev
