PC RAM
x 1056
Re: PC RAM
Unread post by wheeler »
Paul-R wrote: 27 Feb 2021, 18:52 Have to say I disagree and I would recommend a single stick of memory. That way if you decide to upgrade to even more memory you'll have an empty slot ready and you won't have to discard the two sticks if you go the other route.
This is my thinking on it too, means i can also throw the 4gb one in too & if it works then bonus, if not then take it back out.
Armidillo
(Donor 2022)
x 274
Re: PC RAM
Unread post by Armidillo »
Gibbo2286 wrote: 28 Feb 2021, 13:21 I've got a sizeable extended family just up the road from you Alec (in oz terms :) ) in and around Brisbane.
That'd be too hot for me! Much better climate here in the New England region (3200 feet above sea level).
x 1918
Re: PC RAM
xantia_v6 wrote: 28 Feb 2021, 18:35The memory management hardware that Lenovo use on their laptops will handle mismatched memory, and I have had brand new laptops from Lenovo fitted with 4+2 and 8+4 GB.
How very unusual, I didn't know that.
xantia_v6 wrote: 28 Feb 2021, 18:35You lose nothing by trying anyway.
Very true.
x 1056
Re: PC RAM
So stuck an 8gb stick in & the PC recognised the 12gb in total. Definitely a massive notable difference, crucial says I can go up to 16 gb so might get another 8gb stick to replace the 4gb one.
moizeau
x 429
Re: PC RAM
Unread post by moizeau »
Unless you've got a very high end laptop you probably won't see any further gains increasing ram further, the bottleneck will have moved. You can check this in 'Task Manager' the click on 'performance'. This page will show you how much Ram, CPU is being used.
Pete
x 1918
Re: PC RAM
My next move after doubling the RAM to 8GB in my laptop was to change the spinning discs hard drive for a SSD. That really had a quite noticeable effect on boot-up time and general responsiveness. I might go to 16GB next or, just possibly, change the CPU if it isn't soldered to the motherboard.
When I did this some ten years ago on my then laptop I changed from a 1.5GHz Celeron to a 1.7GHz Pentium M and that made quite a big difference. Theoretically there is an upgrade path for the processor which I researched a few years ago. That had something like a 90% chance of working - not soldered to the motherboard permitting.
