C4 VTS - Driver side carpet is wet
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I just noticed that the driver side carpet (LHD) is wet. I peeled off the rug a bit and the floor under the rug was a bit wet. The liquid that wetted the carpet is a little greasy, so I guess it's the coolant (this is Citroen's original coolant). A few months ago I had to add coolant - albeit a small amount. I added several times - and after that the water level seems to be stable and there is no need to add more coolant.
Could this be a leaking heater matrix? How can I verify this? The picture shows the area that was wet after I dried the liquid (coolant?) l.
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
(Donor 2022)
x 8
Re: C4 VTS - Driver side carpet is wet
Hi
Any ideas ?
x 1061
Unread post by wheeler »
The easiest way to tell if its coolant is the taste test. When i say taste i mean dab a little on your tounge with your finger, you will know straight away if its anti freeze.
Alternatively just remove the heater matrix & have a look, its a fairly easy replacement job on the C4 as no need to remove the dashboard (not a RHD model anyway).
lancia58
(Donor 2022)
x 8
Hi
Is there any how to guide for changing the heater matrix on the C4 ?
x 1061
This any good? As far a heater matrix jobs go the C4 is one of the better ones. Never done a LHD version but it looks pretty much the same as RHD.
This any good?
