Air vent behind and adjacent Xantia HDi glovebox.
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
This is an example of my frustration and I suppose it comes with experience.
I was hoping to get dash fully built back up today and I am nearly there.
However, I am trying to locate the air vent extension tube behind the glovebox. I’ve got it located but I tried to remove the side vent itself and have only so far. I don’t want to break anything.
Got it so far out but now cannot get it back in!
And there is a white plastic brace on the tube which is supposed to locate and perhaps screw? onto the rear of the dash.
Any ideas guys?
The beauty is it will be much easier the second time around...
admiral51
(Donor 2026)
x 391
Re: Air vent behind and adjacent Xantia HDi glovebox.
Unread post by admiral51 »
From memory i think to get it out fully you need to squeeze both sides or lever it out.
If you look you can see the locating lug hole on the inside of the vent.
I think the plastic bit is part of the vent mechanism so need to get it out fully before you can get it back in
x 3304
Rhothgar, might I suggest you start a 'blog' thread for this Xantia, detailing what you have done, what you are doing, and what you need help on. One thread is easier to follow (and maintain) than several. This is why I ask for help in my thread "My turn for a C5!".
x 8353
Of all the Xantia dashes I've had out to do heater matrixes I never once felt the need to disturb these side vents...
Why did you feel the need Roger?
James makes a good point... A blog would be really good to see in the Blogs area... The work you have done is always a good read and to have it all in one place would be great ;)
Rhothgar
(Donor 2026)
x 221
Hell Razor5543 wrote: 14 Mar 2021, 15:40 Rhothgar, might I suggest you start a 'blog' thread for this Xantia, detailing what you have done, what you are doing, and what you need help on. One thread is easier to follow (and maintain) than several. This is why I ask for help in my thread "My turn for a C5!".
I've thought about this only the other day. Once I've sorted the live threads I'll certainly do a separate blog.
Rhothgar
(Donor 2026)
x 221
CitroJim wrote: 14 Mar 2021, 17:22 Of all the Xantia dashes I've had out to do heater matrixes I never once felt the need to disturb these side vents...
It was when I stripped it down to put the oscilloscope on the transponder and alarm.
Rhothgar
(Donor 2026)
x 221
admiral51 wrote: 14 Mar 2021, 15:17 From memory i think to get it out fully you need to squeeze both sides or lever it out.
I think I've gone beyond that Colin.
I can't even thump it back in and, believe me, I am trying hard! It just seems stuck.
x 8353
Rhothgar wrote: 14 Mar 2021, 18:32 It was when I stripped it down to put the oscilloscope on the transponder and alarm.
Gotcha! That's a good reason Roger :)
