Xantia S1 Speakers - What's a good, cheap replacement?
Rhothgar
(Donor 2026)
x 225
Unread post by Rhothgar »
Hi all,
The speakers in my S1 Xantia died quite some time ago.
I did wonder if they could be easily re-coned? Has anyone ever tried that?
Other than that, I am going to look for some replacements.
I did buy some JVC on Amazon which arrived yesterday and despite being described at 15.2 x 15.2 (6"), they nowhere fit the front doors. May use them in the back.
I've been looking at some Sony but they are £45. If I bought the set for front and rear, ie £75, it would be worth more than the car...
What experiences have you had?
PS Battery drained overnight. I think the positive and negative speaker cables were touching each other. Battery now on charge.
x 1750
Re: Xantia S1 Speakers - What's a good, cheap replacement?
Try looking at the Pyle Audio website, in particular their PDMW5 (5"). Now have these in the BX.
There's also a PDMW6 (6"), which I have in the XM.
The Pyle site has full drawings and dimensions, and the units are available on Amazon.
Just an idea.
Xantippa
x 29
Unread post by Xantippa »
Pretty much every standard 6,5" speaker should fit on front doors of Xantia. I even had these https://www.amazon.co.uk/Monacor-Predat ... B000K78CC6 on my Xantia, just had to cut speaker frame a bit because those are non-standard 6,5" speakers with larger diameter frame.
I think rear speakers are 5 1/4" size, so 6,5" speakers won´t fit there.
admiral51
x 389
Unread post by admiral51 »
I have these from a Mk2 xantia if it helps
Colin
Rhothgar
(Donor 2026)
x 225
They look to be in good nick.
What you looking for for them please Colin?
Could do without buying new now as I broke the windscreen this afternoon....
admiral51
x 389
Just postage cost nothing more than that Roger
I am 99.9% sure i have the dash speakers also if you need them as well.
Colin
Rhothgar
(Donor 2026)
x 225
PM me some details and I’ll get payment across for the postage.
I am, of course, assuming they fit straight into an S1.
I ought to check my own spares boxes but they are a nightmare to get to at present.
admiral51
x 389
If someone can check that MK1 and MK2 speakers are the same then happy to send you the complete set, i also have the grilles for i think both front and rear doors also.
Rhothgar
(Donor 2026)
x 225
Screw holes across diameter are 155mm apart (6 1/8”). They are 165mm overall to the extreme diameter and 60mm deep. That’s all I can tell you.
I ‘think’ the rears are 135mm. I say think because I offered up the new ones I’d bought that were supposed to be 6” and they look about right.
