Wonderstuff....
bxbodger
Wonderstuff....
http://www.speedydelivery.co.uk/easy-fu ... n-bx.shtml
All that for £4.95!!!!!!!!!!![?][:0]
But no picture, specifications, etc.............I reckon its a cheapo ekotec variant.
I wonder how many they have sold and why I can't find one on my neighbours Vectra, despite G.M. having invented it, whatever it is!!!
Dave Bamber
The first question of the Q&A-
Q. Will the 'Easy Fuel Saver' void my Citroen bx car warranty ?
A. No. Since 'Fuel Saver Device' is an aftermarket removeable device, it will not void your vehicles warranty.
WARRANTY! Didn't realise Citroen extended one this far[:0]........And they can't spell removable[:0]
Snake oil.
Snake oil.
bxbodger
Not snake oil, but a fine piece of advanced space age technology!!!!!-just look at this shiny knob you can get from them for only £29.95http://www.speedydelivery.co.uk/car-tun ... n-bx.shtml- looks good, eh? According to their list of applications it will fit a Maxi, a 2cv, a Testarossa, you name it-and it goes up to 10!![:p]
I can imagine that trying to fool a 2cv's or Allegro's 'computer'.
Do you think I would get my money back if I complained that I can't find anywhere on my BX17RD to attach the wires to, or the chip below? At least I could fit a £4.95 fuelsaver............if I could get the Powerboost controller to work I think I'd need it!!!
Kowalski
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">
Our Power Mod fools your cars computer into thinking that your carss engine is sucking in air at a lower temperature, hence the timing is advanced. Timing advance helps produce more power by igniting the sparks sooner, providing more time for the fuel / air mixture to burn completely, increasing cylinder pressure, thus providing more power
Its a cheap and easy way to advance your ignition until your engine breaks, and fully adjustable too. Not enough pinking to burn a hole through a piston? No problem, just turn the machined aluminium controller clockwise.
Q. Will this device damage my car ?
A. Absolutely not. Since the altered signal will always stay within the Citroen bx cars's specifications, there is no way for your engine to get damaged in any way
Basically, it either damages your engine or does nothing useful, and in any case Maplin will sell you a variable resistor for less money.
bxbodger
oilyspanner
martyhopkirk
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Bamber</i>
WARRANTY! Didn't realise Citroen extended one this far[:0]........And they can't spell removable[:0]<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Bugger, you mean they wont fix my ball joints under warranty - was thinking of going to the dealer that oh so impressed me with their service to demand a new set.
bxbodger
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Bugger, you mean they wont fix my ball joints under warranty <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Just get rid of that 'orrible complicated french thing and get a Rover!! My local MG Rover dealers are now so desperate to shift the things that they are offering a free LIFETIME warranty on every new AND used Rover they sell; they've got so many still sitting around even at drastic discounts that there's nowhere to put the Hyundai stock.
How much a lifetime warranty is worth if there's no-one left to manufacture the parts is anyones guess, however.........
madasafish
Dave Bamber
Jon
FrenchLeave
oilyspanner
fastandfurryous
- x 4
Those surface dischage plugs do work, but you need a very very good ignition system for them to work properly. The breakdown voltage of air is about 3Kv/mm so if there's a 2mm gap between the central electrode and earth, the system needs to be able to generate 6Kv as a minimum (probably nearer 10Kv to be safe) which is quite a lot!
The Alfa-Romeo water-cooled flat-four from the AlfaSud/Sprint/33 had these plugs as standard, and damn expensive they were too! I remember paying over £20 for a set of 4, for a 33 engine in a kitcar once, and that was nearly 8 years ago. They can't have got cheaper!
The engine was a screamer though. 8000rpm without too much trouble!
- x 8168
Really back on topic now... That resistor will fool the ECU into richening the mixture rather than change the timing, hence causing a little more fuel to be injected. Works in much the same way as a pressure regualtor that puts the fuel rail pressure up. Like this the injector flows more fuel for a given pulse witdh. Nett result in both, a rich mixture and slightly less power under most conditions and a bigger petrol bill...
I used to use surface discharge plugs in my 100cc TKM Kart racing engine many years ago. It also used R40 oil - lovely smell!!!
