PC RAM
- x 3295
Re: PC RAM
I would go the route of two memory cards totalling 8GB rather than one 8GB card. Memory interleaving (if it cannot be implemented on a single card) really comes into its' own if an even number of banks are populated with identical RAM. The increase in performance is not just because more can be held in memory (so reducing the amount of HDD access). RAM, because of its' limitations, has to continually run a refresh cycle, so half of the time its is in the opposite state from that you need (depending on what you are doing). Memory interleaving gets around this very efficiently, so the performance of the computer (where RAM is concerned) can, at the very least, double.
OnlinePaul-R
- x 1919
Re: PC RAM
Have to say I disagree and I would recommend a single stick of memory. That way if you decide to upgrade to even more memory you'll have an empty slot ready and you won't have to discard the two sticks if you go the other route.
In addition, memory interleaving is uncommon nowadays except in servers. It's highly unlikely your device will support it.
- x 8059
Re: PC RAM
Taking into account Paul's comment here is another ebay lot:
https://www.ebay.co.uk/itm/RAMAXEL-16GB ... SwpcFf59B8
- x 3295
Re: PC RAM
One thing to do is to see how much RAM your laptop can support. Just because a memory card can physically fit does not mean the computer can logically address it. I bought a 4GB card for my netbook, only to find (after checking the technical information) it could only address 2GB RAM! With the 4GB card in the netbook wouldn't even boot up.
Onlinemyglaren
- x 5648
Re: PC RAM
I recently did just that, huge performance increase and the option to stick another card in if and when..Paul-R wrote: 27 Feb 2021, 18:52 Have to say I disagree and I would recommend a single stick of memory. That way if you decide to upgrade to even more memory you'll have an empty slot ready and you won't have to discard the two sticks if you go the other route.
The Crucial tool was great, used it a lot when I still had Windaz. Doesn't work with Penguin based operating systems.
- x 6954
Re: PC RAM
Be wary - most systems require memory to be matched in pairs - so you may not be able yo put one bank of 8 Gb in - it will likely need 2 x 4 Gb, or if the system supports it, 2 x 8 Gb for 16 Gb. What does your system currently have - 2 x 2 Gb chips or 1 x 4Gb? That should give you a clue as to whether it needs to be installed in pairs or not.wheeler wrote: 27 Feb 2021, 18:13 Thanks, Depending on prices & availability i may just try to get a single 8gb one.
- x 1056
Re: PC RAM
It currently just has 1 x 4gb & the other slot is empty so i guess that means a single 8gb should be OK?
- x 1438
Re: PC RAM
Lenovo seem to regularly ship PCs with uneven memory sticks, so a single stick whould be OK. It should also work if you put the existing stick into the second socket to give you 12Gb, but it seem safer to put the bigger stick into the first socket.
- x 6954
Re: PC RAM
Yes, should be fine then.
OnlinePaul-R
- x 1919
Re: PC RAM
Highly unlikely you will be able to put different sizes in the two slots. I wouldn't take the chance and would either go for a second 4GB stick or a single replacement 8GB stick.xantia_v6 wrote: 28 Feb 2021, 07:57...put the existing stick into the second socket to give you 12Gb.
In essence this is what I did a few years ago with the two laptops my wife and I use. They are (or were!) identical units and I ordered a single 8GB stick for my laptop and then put my old 4GB stick into her laptop. We both now have 8GB of memory installed but mine has a simpler, and cheaper, upgrade path to 16GB.
- x 2941
Re: PC RAM
You lot had me going
I did the Crucial upgrade test and it tells me I can have 32Gb on my desktop, 4 x 8Gb instead of the 8Gb already fitted, nearly went ahead but then thought do I really need it?
Armidillo
- x 274
Re: PC RAM
Now you've triggered my memory - in 1992 I was working for IBM Portsmouth (Cosham). We contractors worked on dumb terminals connected to the mainframe, but the permanent staff were given IBM PS2s with 32 MB of RAM!!! This allowed them to run multiple mainframe terminal sessions - can't remember them doing much else with themGibbo2286 wrote: 28 Feb 2021, 11:58 You lot had me goingI did the Crucial upgrade test and it tells me I can have 32Gb on my desktop, 4 x 8Gb instead of the 8Gb already fitted, nearly went ahead but then thought do I really need it?
At the same time, for personal use I had a 286 laptop (purchased in Singapore on the way across) with 1 or 2 MB of RAM - perfectly adequate for DOS and the early version of Windows I was running!
Cheers
Alec
- x 2941
Re: PC RAM
I've got a sizeable extended family just up the road from you Alec (in oz terms
) in and around Brisbane.
- x 3295
Re: PC RAM
The more RAM you can fit into a computer the faster it should perform. RAM is much faster than HDDs (or SSDs), and if you have a lot of RAM applications can load more into memory rather than swapping information between a Swap File (which is an area of HDD set aside as pretend 'memory') and RAM. I have 64GB RAM, and my gaming PC really shifts!
- x 1438
Re: PC RAM
The memory management hardware that Lenovo use on their laptops will handle mismatched memory, and I have had brand new laptops from Lenovo fitted with 4+2 and 8+4 GB. You lose nothing by trying anyway.Paul-R wrote: 28 Feb 2021, 11:28Highly unlikely you will be able to put different sizes in the two slots. I wouldn't take the chance and would either go for a second 4GB stick or a single replacement 8GB stick.xantia_v6 wrote: 28 Feb 2021, 07:57...put the existing stick into the second socket to give you 12Gb.
