2021 Updated PSA Engine Oil Guide
Forum News, Announcements and any issues you're having with the forum
x 6957
The 'PSA Recommended Engine Oil' guide that I put up on the Forum Wiki many years ago needed updating to account for the latest engines.
This guide also includes Yunnei, Toyota, Mitsubishi, FIAT, PUMA & SOFIM engines used on some PSA vehicles.
The guide is far more comprehensive and details each of the specific countries that PSA class as [Temperate / Cold], [Arduous] & [Very Arduous] to further help determine the correct oil to use.
I won't be placing this on the Wiki as this guide took several days on and off to code up for the Forum.
It is in the Resources section of the Forum for current donors:
Update:
The guide is available in the Citroen, DS & Peugeot Technical Forums as a sticky, available to all.
x 8119
Re: 2021 Updated PSA Engine Oil Guide
Excellent job Marc, just had a quick scan and it will prove very handy. Thanks :)
x 1943
Phew, that's comprehensive.
Armidillo
(Donor 2022)
x 274
Unread post by Armidillo »
I knew that Australian conditions were "Arduous" - I now know we rate as "Very Arduous" :shock: !
Thanks for posting.
Steve Walsh
x 518
Unread post by Steve Walsh »
Hi Marc
Just had a read through that, Very comprehensive,
You are one top bloke spending your time doing something like that for the benefit of others.
Thanks very much for all your work helping me and others on this forum.
Steve
x 6957
No worries, I've put in the the restricted resources section with some other guides as and when I can do these - just to give a little something back to donating members.
x 6957
I've decided to make this later guide available to all as it's of such importance, especially with the impact the oil type can have on later vehicles. It's therefore been replicated to the Citroen, DS & Peugeot Technical Forums as a read only 'Sticky' and requires no membership upgrade to view.
