OEM part nos for C3 parts, anyone got access ?
charentejohn
Unread post by charentejohn »
I used to be able to log on but they changed it and now I think it is pros only. As ever various options so an OEM would help. I need new front shocks, and may as well fit rears at the same time.
Car is CITROËN C3 I (FC_) 1.4 16V VIN : VF7**************[VIN obfuscated, can be read by forum staff]
For example there are two sets look the same and decommended when I put in my reg no, but they have different OEM lists ? https://www.oscaro.com/jeu-de-2-amortis ... Wzeg4EsNsE
Last but not least I apparently need a load of bits at the top of the strut such as rubber pad and metal bit. All in good order, a new rubber pad may be worth it, question is why do different shock absorbers have different top fittings since the springs are the same ?
Any help apprecieted John
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
charentejohn
Re: OEM part nos for C3 parts, anyone got access ?
I see the vin has been blanked out, no problem sharing it. If the check can be done by reg no (French) it is DN 839 WT
x 6963
The VIN blanking is intentional - only Staff can see it for your protection.
As for live parts info, we can assist you but we ask for a min. £10 Forum donation as this data has been chargeable for some time. This will cover you for parts info and parts diagrams requests for up to 2 years. Details below to upgrade your membership:
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
charentejohn
I appreciate the need for a charge but will skip it if you don't mind. Just that I don't work on cars anymore and this is just a one off as they are being awkward, how it works here proper dealer parts or forget it. Most garages won't fit parts you buy, inclined to have one last go and do it myself but would rather a garage did it. :) No worries John
x 6963
No problem, it's just that PSA now charge us for this data - and for what it would cost you for half an hour of timed access yourself gets you up to 2 years of parts enquiries via the Forum.
At least you know there is an option in future.
