807 wishbones
- (Donor 2021)
- My Cars: 1982 GSA 1299
1984 bx 1600
zx 5 door x 2
xantia estate
dispatch
xara picasso
806
807 SE - x 4
807 wishbones
Following on from my minor inccident with my 807 coil springs, i thought i would go ahead and change both front wishbones, a reasonably safe job compared to nasty coil springs.
£197 + vat each from peugeot so thats a no go for me. I started doing an online search for cheaper options, and WOW such a large price variation £70 to £300 a pair.
I'm not talking just fleebay a search of about 10 different online parts companies has a huge variation. And although Peugeot say there is only one wishbone option for my car a lot of the online sellers are convinced there are two variations.
Does anyone have an 07 plate 2.0 litre hdi 100kw/136hp and without having to go out roll about in the rain know if the bolt/studs are 12mm or 14mm. I assume they are 14mm as everything else underneath the car seems to be built for the army to use.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5646
Re: 807 wishbones
2 of the bolts are the same, M14. The other single bolt is 14X150-80 (but will need confirming when exact engine type is known).
Reason: Clarified Info
- (Donor 2021)
1984 bx 1600
zx 5 door x 2
xantia estate
dispatch
xara picasso
806
807 SE - x 4
Re: 807 wishbones
WOW i really appreciate such a fast and concise answer, where are all these suppliers getting the 12mm and 14mm variations from.GiveMeABreak wrote: ↑15 Feb 2021, 12:05 2 of the bolts are the same, M14. The other single bolt is 14X150-80
or are they refering to the lower joint which is "17mm cone"
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 807 wishbones
We only use live PSA parts data direct from PSA.
If you think you'll want parts information and parts diagrams in future, then a £10 Forum donation will cover your for such requests for up to 2 years on Peugeot / Citroen vehicles.
Details below if your are interested:
If you decide this may be something useful, just pop your VIN up (auto masked from public view on submission) and what it is you need and staff should be able to help you
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
Donate Further Information |
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
- (Donor 2021)
1984 bx 1600
zx 5 door x 2
xantia estate
dispatch
xara picasso
806
807 SE - x 4
Re: 807 wishbones
i'll diary that and donate more often as i'm keen to see great sites like this keep going for good of the members either browsers or contributers
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 807 wishbones
Thanks, it also allows us to keep the Forum advert free, which has to be a bonus
- (Donor 2021)
1984 bx 1600
zx 5 door x 2
xantia estate
dispatch
xara picasso
806
807 SE - x 4
Re: 807 wishbones
So are there 2 different wishbone variants with bolt sizes ie 12mm and 14mm and different cone (balljoint) sizes ie 17mm and 19mm. As a lot seem to sell the 12mm variant, but non seem to advertise the 14mm variation.
a bit strange for such a vital part.
I assume the 12mm version is for the lighter petrol models.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 807 wishbones
They vary from model to model - there are 12 variants so that's why I need a VIN to make sure these are the ones you require - even the 2.0 Diesel engines differ. So the sizes I quoted before may not be correct for your specific Diesel. I can confirm once I have it.
- (Donor 2021)
1984 bx 1600
zx 5 door x 2
xantia estate
dispatch
xara picasso
806
807 SE - x 4
Re: 807 wishbones
ok 12 variants lol.
vin number is VF3**************[VIN obfuscated, can be read by forum staff]
Reason: Corrected VIN
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 807 wishbones
I think you had 2 extra characters / digits in there - it should end 997.
If so, you have the DW10BTED4 engine, manual 6 speed with particle filter, RPO 11146. Ok, so looks like I was on the money with the previous bolt sizes:
Screws (7) are the M14s, Part 352278
Screws (8) are the 14X150-80, Part 352279
As for the wishbones, you have a choice: (have a whisky ready)
Original OEM brand new ones are:
Right: 1607510780 £452.92
Left: 1607510680 £452.92
PSA Cheaper alternatives:
Right: 1635774780 £238.19
Left: 1635774880 £235.19
All prices VAT inclusive from Peugeot as of today.
- (Donor 2021)
1984 bx 1600
zx 5 door x 2
xantia estate
dispatch
xara picasso
806
807 SE - x 4
Re: 807 wishbones
OMG its ok got a fresh bottle whilst shopping this week.
seems it would be worth getting the bushes and ball joint "genuine" seperately and get them fitted to the wishbone by a garage.
the vin was exactly as i gave it, took a photo of the bottom of the windscreen.
thanks for your help and info, I might do a video and post it up to help others wanting to have a go themselves.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: 807 wishbones
The photo was probably OK, but you must of added an extra 2 - it had 19 and it should only be 17 alpha numeric - I've edited your post to correct it, but all done now.
At least with the part numbers you can search for these online - sometimes the dealers have a clear out so you can get the genuine ones for a lot less.
- (Donor 2021)
1984 bx 1600
zx 5 door x 2
xantia estate
dispatch
xara picasso
806
807 SE - x 4
Re: 807 wishbones
sorry just checked vin and added an extra nine.
ended 972
ended 972
