Suspension fluid reservoir
- (Donor 2021)
- My Cars: Current - '09 Citroen C5 Exclusive Tourer 2.0 HDi
Previous-
'97 Volvo V90
'05 Merc C320 CDI estate
'08 Volvo V50 T5 R-Design
'10 VW Golf 1.6 TDI estate
Evening all
I brought a 2009 C5 a week ago and when I picked it up the bloke told me he'd topped up the suspension fluid reservoir and it looked like he'd spilt some. I've cleaned the excess off and then today it was pointed out to me by a tyre bay that there was more fluid around where the bottle is.
Is it possible that if the bloke over filled it the fluid is escaping from the cap? Or is it a thing that bottles leak?
Any info will be greatly appreciated.
Cheers
Cheers
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Suspension fluid reservoir
He's probably over filled it. The LDS fluid level MUST be checked with the suspension set on the LOWEST level and should only be filled to between the 2 small ring marks that you can just see at the bottom of the neck. Overfilling it can lead to a burst tank and worse, the fluid can get into the pump and destroy it rapidly.
- (Donor 2021)
Previous-
'97 Volvo V90
Brilliant thank you for that info Marc. The marks that you mention are down the actual filler neck once you've removed the cap?
I've been told that a machine is needed to properly check the level?
Will the car warn me if the fluid is to low? Forgive me if that's a stupid question. This is my first car with hydro suspension.
Cheers
George
Cheers
George
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Hi George. The hydraulic system can be FULLY depressurised using Diagbox, which is the proprietary diagnostic tool, but that is not really needed to check the level as there is an allowance for this. Overfilling is far more of a problem.
Yes there is a warning if the fluid is too low.
These are the marks I was referring to:
Have a read of this post, which may also provide you valuable information if the car is ever going to be lifted off the ground with the wheels hanging freely (for example when having tyres changed):
https://www.frenchcarforum.co.uk/forum/ ... hp?t=62058
- (Donor 2021)
Previous-
'97 Volvo V90
Thank you very much again Marc that's very helpful.
- (Donor 2021)
Previous-
'97 Volvo V90
Having read through that post I really bloody hope the tyre bay haven't popped the tank. They've been going for well over 30years so I assumed they knew what they were doing. I might pop back in there tomorrow.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Just because a company has been working for a long time does not mean they know everything that could pass their doors. Several years ago I went to get some tyres fitted, and the mechanic did not look happy that I had a Citroen C5. He said that they had problems 'recovering' their jacks from underneath Citroens in the past. I raised the suspension to its' full height and then loosened off the cap. Once they had done the work and dropped her back down she remained at full height (and didn't bottom out, which was what the mechanic had expected would happen). The mechanic was surprised, and said that he would have to remember that trick (and did the next time I called in for tyre work).
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- (Donor 2021)
Previous-
'97 Volvo V90
Mmmmm perhaps I need to question their techniques. Although I'm sure it'll feel like I'm questioning their quality. I know for next time when it comes to booking the car in anywhere.
- (Donor 2021)
Previous-
'97 Volvo V90
Out of curiousity if the LDS tank has burst then what sort of cost am I looking at for replacement? Just thinking worst case scenario.
- white exec
We produced some Warning Labels (with fitters/repairers in mind), which can be placed near the reservoir or elsewhere.
You can download the printable pdf's here...
viewtopic.php?p=602414=LDS+tank+burst#p602414
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
It's not so much the tank - it's the damage the LDS does. The reservoir sits on the BHI and pump. If fluid is overspilled at any time it should be cleaned straight away, as if it drips down onto the BHI, it can get into the seam of the unit and penetrate. It then mixes with the carbon brush material and forms a thick sludge / paste that then causes overheating and shorting which blows the main 40/50A fuse and can damage the pump unit. These are expensive to replace.
The tanks are from £60-£80 and the BHI incorporating the pump on a 4 cylinder model is about £1600 plus VAT and fitting, plus LDS fluid that is anything up to £16 a litre!
- (Donor 2021)
Previous-
'97 Volvo V90
Forgive me but what is the BHI? What is the best stuff to clean the fluid away with? Brake cleaner? I take it the BHI is all to do with the suspension fluid yeah?GiveMeABreak wrote: ↑10 Feb 2021, 10:18It's not so much the tank - it's the damage the LDS does. The reservoir sits on the BHI and pump. If fluid is overspilled at any time it should be cleaned straight away, as if it drips down onto the BHI, it can get into the seam of the unit and penetrate. It then mixes with the carbon brush material and forms a thick sludge / paste that then causes overheating and shorting which blows the main 40/50A fuse and can damage the pump unit. These are expensive to replace.
Cheers
George
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1383
Flip, that's expensive. For £19.97, you can get 5 litres here -
https://www.ebay.co.uk/itm/Hydraulic-Fl ... Sw9uBamtMX
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I thought I'd go down the middle, seeing as this one is £38.05 a litre....
https://www.ebay.co.uk/itm/164002242646
- (Donor 2021)
Previous-
'97 Volvo V90
Christ that's liquid gold surely? How much does the whole suspension system hold?GiveMeABreak wrote: ↑10 Feb 2021, 14:13 I thought I'd go down the middle, seeing as this one is £38.05 a litre....
