Xsarra Picasso Desire 2007 Non Functional Key?.
Minuno
Hello there can I ask this question please, last weekend my partner asked me to try and find her a Picasso Desire to replace her other one which failed the MOT the day before. Well after a little searching I found a nice one for her at a good price.
Only thing is the push button key that came with it ( came with two keys one programmed with the two buttons and a solid key both of which open the car door and start the car successfully ) doesn’t operate when you press the open and close button on it. It’s broken and doesn’t work.
She needs to have the programmable option and could anyone offer any advice?.
I have noted that when I lock the door with the key manually the red hazard button on the dash is slowly lighting up red on and off?, this happens constantly until the car is open again?. Is this a fault or is it due to not having the programmable key please?. I’m thinking it will drain the battery quickly ?. Any advice appreciated.
- x 3298
Re: Xsarra Picasso Desire 2007 Non Functional Key?.
It does depend on WHAT the problem is. If, for example, the rubber membrane has failed, you could consider buying a replacement 'shell' from ebay for a few quid, and then transfer the membrane over. If, however, the buttons themselves have failed (and you are good with a soldering iron) you can buy a repair kit which will have some new switches. This is such a repair kit;
https://www.ebay.co.uk/itm/Fits-Citroen ... %3A2334524
I don't, however, know if it the right one for YOUR car (or, rather, your sisters' car).
Minuno
So you think the circuit board could be repaired ? By someone?.
What’s the red light flashing in the car within the hazard warning light. When you shut the door physically with the key in the lock this light comes on and is slowly illuminating constantly on and off.
- x 3298
I don't know about the flashing light in the hazard warning light. I just went for that I knew. I would doubt repair kits would sell if it were not possible to replace the switches.
Minuno
Could I ask how you would proceed to get the confidential key code card for the car please?. It didn’t come with one to get a replacement key done perhaps
- x 3298
You will need to contact a dealership with proof of ownership. They may well charge a fee for this (most do, some don't).
- x 1056
Nobody has mentioned the obvious here but have you tried replacing the battery & confirmed the battery is the right way around?
Have you tried re syncing the remote by switching the ignition on & holding the lock button for 10 seconds then switching off & trying the buttons after 30 seconds?
The red flashing light in the hazzard switch is normal, its just a security deterrent to show the immobiliser is active.
Minuno
Thanks for the assuring me about the red light on the dashboard, my partner thought I’d bought her a faulty car as her 2004 version didn’t have this on her dashboard. I did replace the battery last evening but didn’t try to reset the remote will try that but I doubt it will work. But worth a try
Minuno
Is there any way to programme a new pair of keys myself please if I get access to this code card via a dealer?, I have been quoted £200 for two keys as I haven’t got a working original working programmed
key from a locksmith
- x 1944
There are two aspects of programming a key with remote lock/unlock buttons.
The first is pairing the key to the car so that it will start the car from the ignition. For this you need a code reader such Diagbox and the key code that has already been talked about. With these you can pair a brand new key to the car or re-pair a key which has lost its pairing or been deliberately removed from the list of recognised keys (if you've lost it for instance). You cannot pair a key that has been paired to another car; the chip inside is one-time programmable only.
If your key starts the car then it is working. A competent locksmith can make a clone from this.
The second aspect is syncing the buttons to the car so that they lock and unlock it remotely. This does not use Diagbox and is the process is described by Wheeler three posts above. It is completely separate to the pairing process. You can only sync a key that is paired to the car.
It is possible to have a key that will start the car but the unlocking part is broken. Is this the situation you are in? I am a little confused.
Minuno
To Paul R above, yes the key opens the door which inserted into lock and it starts the car no problem. What if doesn’t do is open and shut the doors via pressing either of the buttons.
- x 6948
That's simply down to the type of fob you have bought- they are not all of the same frequency type or of equal quality.
The electronics are obviously not compatible. Although the transponder chip has been programmed, the other electronics for the remote functions are separately controlled using a receiver in the car. If it's not receiving the correct frequency the BSI won't authorise the locking / unlocking of the doors.
Minuno
The key is the original as supplied with the car?, the circuit board device isn’t functioning now ?.
- x 6948
Are you sure it is an original Citroen fob or a second hand one that looks original? If you don't know the history, it may of been replaced previously with one that has the issue I described.
If it is an original, then as mentioned somewhere else it may be the microswitches have come loose / unsoldered. This can happen after being dropped on the ground over and over again.
Minuno
Yes true, but I’m thinking it is original it looks well used to be honest the plastic caps are missing from the plastic cover but it would be very bad luck for the previous owners to lose two original keys I’m thinking?. There is a chap on eBay who say he repairs that keypads for £15 and seems to have good feedback from a lot of people whom have sent the circuit boards to him?.
What would you think is it worth a go ?. Board doesn’t work anyways so could jus send the circuit board in the post?.
https://www.ebay.co.uk/itm/274383247140
