White smoke
x 1746
Re: White smoke
Gibbo2286 wrote: 23 Jan 2021, 10:30 The joke from that is "So that's why my wife has C&A in her knickers."
:lol: :lol: :lol:
Always good to know whether one is coming or going, I suppose.
We might have strayed a bit OffTopic here! :roll:
x 3298
Re: White smoke
white exec wrote: 23 Jan 2021, 11:20
:lol: :lol: :lol:
You mean there is a TOPIC? I prefer Crunchies!
Jonathancilia
x 9
Re: White smoke
Unread post by Jonathancilia »
Today preheated glow plugs, engine started after first turn, but you have to have accelerator pedal pressed abit or it just turns, when its starts if you let your foot off the accelerator pedal it stalls and after is abit hard to start again
x 1746
Re: White smoke
Good news on the glow plugs. Immediate start is what is supposed to happen.
On the Bosch pump, there is a Cold Start thermostat, which opens the accelerator lever slightly when engine (coolant) is cold. This may need adjusting.
Jonathancilia
x 9
Re: White smoke
white exec wrote: 24 Jan 2021, 10:31 Good news on the glow plugs. Immediate start is what is supposed to happen.
I hardly think that its working lol, but if it is maybe how would i go about adjusting it?
x 1746
Re: White smoke
Do you have a Haynes workshop manual for the car? These usually cover pump adjustment in reasonable detail.
If not, can you post a photo of the Bosch pump, and we can look out some adjustment instructions for it.
Jonathancilia
x 9
Re: White smoke
For this car no i dont have, it has the bosch pump, the fast idle cable has like a star wheel on the end of it.
x 1746
Re: White smoke
This Bosch publication might help with adjustments...
http://gershon.ucoz.com/BOSCH/DIESEL/pu ... _Pumps.pdf
Jonathancilia
x 9
Re: White smoke
Exactly as this one
x 1746
Re: White smoke
You'll need some help from someone familiar with that pump.
Cold-start advance or idle-up looks as if it might be internal.
What Bosch model/type number is stamped on the pump?
Jonathancilia
x 9
Re: White smoke
Cold start is on the outside it has a waxstat, today we replaced the fuel filter device and seems to be working better, will report back when car is cold
x 1746
Re: White smoke
OK, if an external waxstat, with puller cable, the cable/lever is adjustable.
When cold, cable pulls tight, and opens throttle a little; when engine warms up, the cable relaxes. Movement is quite small.
Jonathancilia
x 9
Re: White smoke
Oh i see, at the moment when cold and hot cable stays the same
x 1240
Re: White smoke
Unread post by Peter.N. »
Can you not adjust the length of the cable?
Jonathancilia
x 9
Re: White smoke
It has a kind of a spring at the end of it that i think its supposed to be pulled back when cold, so i presume the waxstat is not working
