White smoke
Jonathancilia
x 9
Re: White smoke
Unread post by Jonathancilia »
white exec wrote: 21 Jan 2021, 17:57 Slow/lazy starter motor - check main battery connections: if either terminal/clamp gets at all warm during cranking, replace the clamps with new brass ones, as they have acquired resistance internally.
Check also main battery-engine/gearbox-chassis main earth/ground cable for clean connections, and main Batt+ connection to the starter solenoid.
Use a second (jump-start) battery as well. If that speeds things up, replace the battery.
Thanks will check the connections and earths tomorrow and see from there :)
Jonathancilia
x 9
Re: White smoke
The bosch diesel pump where is it supposed to be on the mounting bolts? It has like an adjustment on slotted holes, ours is almost all the way to the front with a very slight gap is this good?
x 8406
Re: White smoke
Jonathancilia wrote: 22 Jan 2021, 07:15 The bosch diesel pump where is it supposed to be on the mounting bolts? It has like an adjustment on slotted holes, ours is almost all the way to the front with a very slight gap is this good?
It's fine if the timing is correct but worth checking properly... Cold diesel engines need a far bit of timing advance for easy starting as there's a delay been the moment when injection commences and subsequent combustion when the engine is cold so the timing is advanced to compensate...
Possibly, if the static timing of the pump is significantly retarded this could possibly account for both issues...
If, however, the retardation is significant, performance will be well down and the engine will run quietly with very little 'diesel knock'
Jonathancilia
x 9
Re: White smoke
My fathers says its down on power abit, i dknt know as i havent driven it before, the diesel pump is almost fully retarded i think at the moment, its turned almost all the way back to the engine block side. This makes it retarded?
x 8406
Re: White smoke
Jonathancilia wrote: 22 Jan 2021, 07:47its turned almost all the way back to the engine block side. This makes it retarded?
I can't remember now unfortunately... I'd be tempted to move it to the middle of its travel and see if anything changes...
When moving the pump, slacken the injector delivery pipe unions to relive stress on them as the pump moves to a new position...
Jonathancilia
x 9
Re: White smoke
Ill try that thanks
x 1240
Re: White smoke
Unread post by Peter.N. »
Turning it in the direction of rotation will retard it and vice versa. I think it rotates clockwise looking from the cam belt end. So you need to turn it clockwise looking from the back of the pump.
Jonathancilia
x 9
Re: White smoke
So as it is now its advanced because the pump is almost all the way clockwise
x 8406
Re: White smoke
Peter.N. wrote: 22 Jan 2021, 10:17 Turning it in the direction of rotation will retard it and vice versa. I think it rotates clockwise looking from the cam belt end. So you need to turn it clockwise looking from the back of the pump.
Excellent Peter, I've learned something today :D
Yes, when looked at from the cambelt end the direction of rotation will indeed be clockwise...
x 1746
Re: White smoke
The endless problems of how to describe something on the car...
Left-Right :?: Driver's seat or when gazing at the engine?
Nearside-Offside :?: Just about pointless; gave up on that one years ago!
Front-Back :?: Still good, except maybe for the new Ami
x 8406
Re: White smoke
white exec wrote: 22 Jan 2021, 17:39 The endless problems of how to describe something on the car...
:-D Absolutely Chris, it's always been a problem :roll:
Left and right as I understand it is when sat in the driver's seat and not when standing in front of the car looking under the bonnet...
Nearside is closest to the kerb (or side of the road) when driving along in a forward direction on the correct side of the road in your country... So your nearside will be our offside :roll: :lol:
Indeed, the new Ami will be a problem... It'll need a sign on it saying 'FRONT' :wink:
x 1746
Re: White smoke
x 3296
Re: White smoke
In Sir Terry Pratchetts' book "Wintersmith" there is a scene where some children are making a snowman. The smallest child (who is wearing so many layers of clothing it is not possible to determine their gender) had had letters embroidered into their clothing; R and L onto their mittens, F and B onto the front and back of their jacket, T on the bobble hat and (presumably) U on the underside of their boots. "This meant that while you couldn't know what it was, you could be certain it was the right way up and which way it was facing".
x 2938
Re: White smoke
The joke from that is "So that's why my wife has C&A in her knickers."
x 8406
Re: White smoke
Gibbo2286 wrote: 23 Jan 2021, 10:30 The joke from that is "So that's why my wife has C&A in her knickers."
:lol: :lol: :lol:
