Hi,
How do I remove internal drivers door trim. There are two screws and then you can ease out pop studs around the edges but something is still not letting the panel release
Removing Front door internal trim DS5 2013 Hybrid
- x 6963
Re: Removing Front door internal trim DS5 2013 Hybrid
Here you go:
Finally
You should be able to disconnect the connectors then as you need.
| Unclip the trim (1) (as "a") using trim tools. Remove the trim (1). | Remove the shields (2) |
| Remove the bolts (3). | Remove the bolts (4). |
| Unclip the door trim pad (5) (as "b"). Detach:
Neilied
- x 6
Hi all. Have had a google and YouTube is their instructions for the rear removal. I am changing check straps front and back. Found a you tube clip but I’m not convinced it has every step thanks in advice
