Xantia S1 central locking
froggy
- (Donor 2026)
- x 4
Hi, my S1 Xantia, the central locking seems to have a mind of its own! as soon as I lock the car , it starts locking and unlocking on its own, for about 6 times! The drivers door has now locked itself and wont open! anyone any ideas? new one on me, cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 1056
Re: Xantia S1 central locking
Pull back the carpet in the NSF footwell & check for water/dampness in the big 30 way connector. One of the main problems you get with water in there is central locking/alarm problems.
If its wet its normally caused by a poorly sealed windscreen scuttle panel.
Worth a quick look first.
admiral51
- (Donor 2026)
- x 391
Was convinced the ECu/conector was under the carpet but could not find a post about it lol
If the door is deadlocked will it open on the key if the battery is disconnected ?
If it is not the connector could it be a broken wire or 2 in the car to door loom ?
