Re: Citrojim's AX, Saxo, Pixo, Running and Cycling Tales
The aforementioned Citroen AX 4X4
- x 3298
More brake cylinders, just in case (but I don't know if they are suitable or not);
https://www.ebay.co.uk/itm/CITROEN-AX-1 ... SwXbhe3KGH
https://www.ebay.co.uk/itm/2x-Wheel-Bra ... SwiItf5yQI
https://www.ebay.co.uk/itm/N-O-S-PAIR-C ... SwExlagK8g
- x 8439
Thanks Richard, not surprised service.citroen no longer lists stuff for the AX...RichardW wrote: 03 Jan 2021, 16:27 The dust cover is 374032, allegedly still available - mind you £10.16 each!! Looks to be common with Saxo, so you should be able to get a pair somewhere.
I'll make some of my own dust caps at at that price!
I now have some cylinders on order from the 'bay, along with a new set of brake shoes
Nice
Today, looking around Facebook I found this AX for sale...
Absolutely and utterly identical to the one I had in the early to mid 90s
This one's on sale for £950.. Either a bargain or a moneypit...
13,500 Euros buys you this variant of the AX
https://www.frenchcarforum.co.uk/forum/ ... 99#p670699
- x 8439
WowNewcastleFalcon wrote: 03 Jan 2021, 17:13 13,500 Euros buys you this variant of the AX
- x 8161
Imagine if they had brought out an electric AX - it would have been cutting edge - AX E
- x 3298
That might be axing for trouble!mickthemaverick wrote: 03 Jan 2021, 17:18 Imagine if they had brought out an electric AX - it would have been cutting edge - AX E![]()
- x 8439
They did do a "first Generation" AX Electrique along with a Saxo Electrique.
The filler cap was probably for the webasto diesel heater
Some gubbins about the Webasto Heater from the archives.
NewcastleFalcon wrote: 22 Jan 2017, 09:45 The engine independant heater was a product of Webasto, who also did this type of thing for buses and boats.
Still going today from their founding in 1901...
https://www.webasto.com/gb/about-webast ... n/history/
and the internet as ever proves once again a tremendous receptacle of reference information....a comprehensive 50 odd page repair manual for the particular fuel-powered heaters fitted to the AX, Saxo, and Berlingo electriques![]()
Yes I know you would have to take a crash-course in German to get the most out of it but there's always Google Translate!
pdf document: Webasto_Thermo_Top_T_BW50_DW50.PDF
regards Neil
- x 8439
Looking at one of the ebay links James supplied for AX cylinders I see some similar to yours and advertised as being for an AX and Renault 19.Gibbo2286 wrote: 03 Jan 2021, 10:52 I've got this sitting on my shelf, it's from GMF it's Citroen but I can't remember what for.
I've cross-referenced this with the BoL and my official AX workshop manuals but I find no trace of this style of cylinger ever being used on the AX, not the small petrols at any rate...
So, they must be for the Renault!
- x 8439
Well found Neil, that's one looker of an AX. I particularly like the colour and paint finishNewcastleFalcon wrote: 03 Jan 2021, 17:31 They did do a "first Generation" AX Electrique along with a Saxo Electrique.
I reckon one of those would suit my daily needs very well... Perfect for my weekly run to Tesco
first Gen tech but probably more than enough even now for your daily needs. It had 51 miles range and 91km/hr top speed. NiCd Batteries and a DC Motor.CitroJim wrote: 03 Jan 2021, 17:36I reckon one of those would suit my daily needs very well... Perfect for my weekly run to TescoNewcastleFalcon wrote: 03 Jan 2021, 17:31 They did do a "first Generation" AX Electrique along with a Saxo Electrique.That's all my car now does whilst we are in Tier 4...
There is some gubbins on the AX Electrique in the spoiler. Pretty simple tech, and standard AX running gear.
- Spoiler: show
- x 3298
Considering that was 27 years ago that is not bad. In fact it is very good.NewcastleFalcon wrote: 03 Jan 2021, 17:55first Gen tech but probably more than enough even now for your daily needs. It had 51 miles range and 91km/hr top speed. NiCd Batteries and a DC Motor.CitroJim wrote: 03 Jan 2021, 17:36I reckon one of those would suit my daily needs very well... Perfect for my weekly run to TescoNewcastleFalcon wrote: 03 Jan 2021, 17:31 They did do a "first Generation" AX Electrique along with a Saxo Electrique.That's all my car now does whilst we are in Tier 4...
- Spoiler: show
- x 8439
To confirm my diagnosis of the reason for Daffodil's non-operational rear brakes I removed one of the wheel cylinders today...
Seized absolutely solid
Even a hammer and punch won't move the pistons!
They are allegedly only 4 years old
Brake fluid replaced at the same time according to an invoice...
The brake fluid is very badly contaminated... As I flush more it's getting more and more purple and my suspicion grows that DOT5 was used to top-up and it's not done any good... It started off black and full of sediment, then brown and now distinctly purple!
New wheel cylinders are on their way and should arrive on Wednesday
I've also procured another litre of DOT4 fluid to enable a thorough flush...
I use a grease nipple in the pipe hole and a side lever grease gun to shift those seized pistons.
