TUD5 timing belt
moizeau
- x 423
Re: TUD5 timing belt
You didn't time the pump then, or you're a tooth out on the belt??
Pete
Jonathancilia
- x 9
When i put the drill bits through the holes they all aligned, but i have to say the pump hub holes were almost all the way to the left. Now i adjusted them almost in the middle
Jonathancilia
- x 9
Even the flywheel pin aligned
moizeau
- x 423
I always mark the belt then transfer the marks to the new belt on XUD's 1/2 tooth?? Which way should I go? Too late now mind. Shouldn't need to move the pump. Hopefully Jim will advise.
Pete
Jonathancilia
- x 9
Its running good now, i drove it and it drives normal, just when cold misfires 2 times and runs like a champ
Jonathancilia
- x 9
I replaced the belt at an opportune time because the tensioner was very stiff, it could have seized up i think. I am surprised as everything i bought 3 years ago was genuine
JohnD
- x 72
Sounds as though the pump is a tooth out. I would go back and put all the timing pins in place again.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Jonathancilia
- x 9
Did that everything lines up now
Jonathancilia
- x 9
While replacing the belt, i noticed a small oil leak coming from the head gasket in the corner, is this normal or to be concerned with? Im not losing any oil between oil changes and not seeing oil dripping under car, just saw a bit of oil that to me it seemed that its under the head only
Jonathancilia
- x 9
I waited till the morning to see how it starts, fired after 2 revolutions only, so its good but it sputtered a bit randomly and white smoke came out, but after a few minutes everything became normal, no more sputters and car runs good with no smoke. Does this mean timing of pump is a wee bit off? Or if it was it would smoke all the time ?
OnlineCitroJim
- x 8400
The only way to be sure the pump is correctly timed is to follow the exact timing setting/adjustment procedure for this particular engine/pump combination.Jonathancilia wrote: 27 Dec 2020, 18:16 Update, spent like 2 hours messing with the diesel pump hub and adjusting, now it runs no smoke while running. However when cold it misfires 2 times and thats it runs like a champ , i need to turn it very slightly to one side i think, which side should i turn the hub? Or i leave it as is
It's never a good policy to do it 'by ear' or by experimentation.
If the car is now running well, I'd be very tempted to leave it exactly as it is... Many diesels misfire a bit when first started from stone-cold and as long as it's very brief, I'd live with it if in all other respects it runs well and starts easily...
The cold misfire may well be due to worn glowplugs or a glowplug post-heating fault... IDI engines like the TUD5 rely on good glowplugs and an effective post-heating regime for easy cold starting and smooth running immediately after a cold start...
Jonathancilia
- x 9
Think i found the issue, there was a paint mark on the pump that someone made before i didnt see that before. The pump toothed pulley is a tooth back. And the three vernier bolts need to be all the way to the right for it to work good. Glow plugsare brand nee. It only misfires a bit whem cold and smokes white.
Jonathancilia
- x 9
However after a few minutes it runs just fine and no misfires
Jonathancilia
- x 9
The timing pins all go in when i put it at tdc. Its just the pumo toothed pulley that is a tooth back from the mark
Jonathancilia
- x 9
When its cold it does like this but clears out after a few seconds
This car is not mine i just found a video that is exactly the same symptom
