Good morning all
My C3 has developed a warning when i start it up ...it Bleeps and a message is displayed saying "Risk Of Particle Filter Clogging" and another "Particle Filter Additive Too Low : Repair needed"
To cut a long story short i have just finished self isolating and the car has been stood for 10 days.....every other day my lad went out to fire it up so i didnt get a problem with the battery........when i parked it up there was not much fuel in it (55 miles worth) and because of isolating i couldnt leave the house to put some diesal in.
I left for work yesterday morning and called at the local Petrol station and stuck £10 in (car was fine on the run to the petrol station).....as i was pulling into the car park at work is when i got these messages on.
When i finished work i took it for a spin up the Motorway to get the engine hot.....kept it in 4th gear doing approx 70mph.....on returning home i switched the engine off and started it back up.....the messages re-appeared.
I spoke to a friend who has advised me to try using Cataclean Diesal DPF Cleaner........would this solve the issue does anybody know or would anyone have any other recommendations as what to do.
- x 3306
Re: Risk Of Particle Filter Clogging
Hi, and
to the forum.
My first question would be "How many miles has she done?". This is because some Citroens have a particulate fluid that does not need topping up often (unlike AdBlue, for example), and those messages suggest there is not enough fluid to make it safely to the next anticipated service.
I would also suggest you post the vehicle VIN here (it will, for security reasons, be automatically obscured so only forum staff can read it), so that if there are two or more possible fluids that could be used they can let you know the correct fluid to use.
I think that what will need to be done is for the fluid to be topped up, and the counter to be reset (normally the system does not have a level sensor, so it counts the number of times it uses a measure of fluid, and when it gets low it throws up the warnings). However, those with far more knowledge than I will be able to give you far more information.
- x 6956
Well the warnings are there for 2 specific reasons:
1) The particle filter is still clogged and
2) The additive level is too low.
What is the mileage of the car?
When was it last topped up with DPF additive?
If the estimated additive level is too low then the vehicle will not be able to undertake assisted regeneration - which means the only way regeneration is going to occur is when the exhaust gas temperature reaches 550° C instead of only 450 °C it would need when assisted.
So I would arrange to get your additive fluid topped up (which will require a diagnostic tool to inform the engine ECU this has been done) and then fill the tank up with fuel afterwards and go for a spin. You don't need to do 70 in fourth gear - just get the engine warm and go for a spin at about 40-50 MPH minimum for an uninterrupted drive where possible.
I suspect the frequent starting of the engine during lockdown without driving has clogged the filter as it has not been allowed to get to operating temperature and then undertake a regeneration. Not a good idea, and you would of been better off leaving the car and just charging the battery up when you were ready to use the car normally again.
doddicus
the car has done 92,000 and ive never added any DPF additive.....im not very mechanically minded and only do the usual oil and water checks.GiveMeABreak wrote: 02 Dec 2020, 11:36 Well the warnings are there for 2 specific reasons:
I apologise for my ignorance........is Cataclean a DPF additive?
- x 6956
No. The DPF additive is a specialised Cerine based fluid that is in injected into the fuel tank automatically when fuel is added. The tanks (or pouches) are stored under the vehicle near the rear and are generally 3 litres (depending on engine and model) and are partially filled at the factory. The process is automatic and computer controlled - you do not manually add anything into the tank yourself. They require topping up at about 70k miles or so with the correct additive depending on engine and build date. It is extremely important to use the correct fluid for your vehicle and some types cannot be mixed.
If it has never been topped up in the 92k miles then I suspect it is empty! When this happens, assisted regeneration cannot take place and then your filter will start to block. Once it blocks to anywhere over 70% it may not be possible to regenerate - so it is important not to ignore the warnings or leave it in this state.
I suggest you take it to a decent garage and ask them to top the diesel additive fluid tank up. However, if your DPF is blocked it may also benefit from a clean - even Halfords offer a DPF cleaning service now - light or deep clean.
doddicus
Is it an expensive repair.... Any rough ideas on how much this would cost
- x 6956
Additive fluid can be bought in 1 litre containers - but it is cheaper to buy the 3 litre filling kits as often at this sort of mileage the tank will most likely be near empty. DPF Fluid is roughly about £33 per litre, but you can get the 3L packs that come with a filling kit if you are doing this yourself - but you will still need somebody with Diabox or a compatible diagnostic tool to reset the additive counter.
This is the cost of owning a diesel which needs to be factored in - you do get better MPG, but you will need to top the additive up once, maybe twice over the vehicle's lifetime and the DPF filter can be cleaned to prolong its life, but they should have a life of about 120k miles or so depending on vehicle and filter type and of course how the car is driven.
Big Dave
- x 3
Quick question, my mum's peugeot 3008 1.6hdi (60 plate) has just popped up the risk of filter clogging message. I suspect the fluid is empty as it has 115,000 on the clock and has only done short runs since July. I took it for a run down the motorway for about 30 miles at roughly 70mph, didn't see any smoke out of the rear so I assume it's not got any dpf fluid left. Attached are pics of the warnings. Message pops up briefly (still shows when pressing spanner button on dash) and the triangle stays on all the time (did go out at first but not now).
If fluid has run out, is it worth adding redex dpf cleaner to the tank till I can get it to my mechanic
I don't have the computer gear to do it myself
Dave
Dave
DS5 dsport blue hdi 2ltr diesel Auto 2015.
No job too small, no hammer too big
- x 6956
Hi, no, this is not the additive warning message - which you will get if the fluid is low and there is insufficient fluid remaining to cover the mileage to your next due service interval as per your maintenance indicator.
This means that the particle filter is at risk of blocking. The system uses passive regeneration (when travelling at motorway speeds) or when the exhaust gasses reach 550°C where regeneration of the particle filter will naturally burn of the particulate matter. At lower speeds where it does not reach such temperatures and starts to clog, the assisted regeneration is initiated by the engine ECU that means the exhaust gas temperature only has to reach 450°C to regenerate the filter.
That being said, where journeys are of particularly low mileage and of short duration, the engine barely has tome to warm up, so even assisted regeneration may be impossible - especially if the process does start but gets interrupted when the engine is switched off.
Although the engine ECU has strategies to deal with this, sometimes it is just not possible if the process is constantly interrupted, at which point the warning you have is displayed.
The recommendation is to go at least 40 mph (and try to stick in a lower gear for a while) to aid the engine getting to temperature for an uninterrupted journey of about 15-20 minutes to allow the engine ECU a chance to regenerate the filter.
Be warned that if left too long and the filter gets any where at 70% full or more that regeneration may fail as the filter will be too blocked, which will necessitate removal and cleaning.
I would not add any DPF cleaners or other additives (Citroen actually state this) to the fuel tank.
The additive level would normally be checked at the dealer's servicing schedules at certain mileages (usually about 70k miles, but depends on engine and vehicle), so if it has not already been topped up, would be worth getting them to check. Of course if you don't have it dealer-maintained it would likely never be checked unless specified.
Big Dave
- x 3
Sound thanks Marc.
I will take her car out for a good run on the motorway again.
Am I to expect smoke out of the exhaust if it is regenerating the filter, or will the light just go out once the car is happy
- x 1938
You shouldn't really see anything coming out of the back except possibly a slight haze. What you might notice is the heated rear window and heated door mirrors in operation as this puts extra load on the engine to encourage regeneration. Some people have fitted a small LED across the heated element in the door mirror casing which then glows whenever regeneration is taking place.
Big Dave
- x 3
Thanks for the help guys, very much appreciated
- x 1485
My guess at those miles is that the ECU has decided the filter is end of life (full of ash). It almost certainly isn't however, and as long as the pressure is OK, then you can just tell it it has been replaced and it will be happy. Needs Diagbox or other decent scanner however... Where are you?
Big Dave
- x 3
I'm in the North west UK, near St.helens.
