Citroen C3 2011 Headlights Help.
jasonlit
Unread post by jasonlit »
Hey everyone, I dont have access to the car right now but I cant figure if this black part is the part of the headlight or bumper? One of the headlights is missing it therefore does anyone know if I'm even able to buy it from Citroen or eBay? Thank you!
Images in attachment!
JohnD
(Donor 2022)
x 72
Re: Citroen C3 2011 Headlights Help.
Unread post by JohnD »
Looking at a diagram of a C3 bumper, it looks as though your circled area is part of the bumper.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
jasonlit
JohnD wrote: 25 Nov 2020, 14:30 Looking at a diagram of a C3 bumper, it looks as though your circled area is part of the bumper.
Thanks for reply! Indeed it does look like a part of it, any chance of removing/replacing it other than buying new bumper?
Edit : On a 2nd thought that bumper doesnt really match mine, there is no cut outs under headlights. Here's the picture of front end in attachment. The missing piece is on the right headlight (left if looking at the picture).
JohnD
(Donor 2022)
x 72
How about this one:-
Sorry - I've removed it. It obviously wasn't a match with yours.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
jasonlit
This is the one I guess, any chance you have image of inside or some other diagram? Wondering if that part is replacable or it's fixed to the bumper.
x 6945
There are 2 versions of the C3 (A51) and the styling is slightly different. From the pictures I think you have an older style and as you can see from the diagram below, the whole of the blue section is the bumper, so to answer the question, the piece I have arrowed in green is part of the bumper and not the headlight. Ignore the black arrows, this is part of a procedure from which I took the image.
Now I can't be certain, but there could also be another part above the bumper (the black part under your headlight in your original picture) but I cannot see anything on the parts to indicate this - I'll have another check now.....
...no, I can't see anything anywhere to suggest there is another part - and as John mentions it is very likely part of the whole bumper assembly.
jasonlit
GiveMeABreak wrote: 25 Nov 2020, 16:18 There are 2 versions of the C3 (A51) and the styling is slightly different. From the pictures I think you have an older style and as you can see from the diagram below, the whole of the blue section is the bumper, so to answer the question, the piece I have arrowed in green is part of the bumper and not the headlight. Ignore the black arrows, this is part of a procedure from which I took the image.
Thanks for very detailed reply and explanation! It's unfortunate it cant be replaced since original somehow broke. Thanks once again guys!
JohnD
(Donor 2022)
x 72
It shouldn't be too difficult to cut a piece of plastic to fit. Then an easy paint job since it's black.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
