Citroen c8 2007 hdi 2.0l none start
craig lawtonawton
I have a citroen c8 2.0l hdi 2007, I was driving down the road when everything cut out and battery light came on, I checked my belt was still on, there was plenty of power to crank it over, to dont think power issue, I pumped primer pump a few times and it turned over, I drove down the road and this happened again about 5 times, so I thought must be fuel problems, i took filter out and started it up it ran fine for about 10 mins, I cut it out so I could put the housing bracket back on and when I tried to start it it wouldnt start, it started on easy start but I ran out, any help would be appreciated.
- x 6947
Re: Citroen c8 2007 hdi 2.0l none start
We really need some fault codes first of all - if you can get a code reader on it (preferably Diagbox), but if not, you should still be able to get any standard faults codes up with a generic code reader. Post them up here with your VIN so we know exactly which engine you have and that may provide some pointers.
craig lawtonawton
Hi mate I will try n get the codes up today I have diagbox will get vin too thanks
craig lawtonawton
Will take a while as got to install it on my laptop
craig lawtonawton
Vin number is VF7**************[VIN obfuscated, can be read by forum staff]
- x 6947
Ok, so just run a full test and let us have any codes picked up.
craig lawtonawton
Ok so put it on and this is a lot lol
A9b8
P1351
P2562
P1443
P0299
P0337
U1118
P1693
U2001
A9b8
P1351
P2562
P1443
P0299
P0337
U1118
P1693
U2001
craig lawtonawton
Cleared codes and the ones that come back are as follows
U1118
P1693
U2001
P1443
U1118
P1693
U2001
P1443
- x 6947
Ok, leave it with me whilst I do some digging
craig lawtonawton
Down to u1118, p1693, u2001
- x 6947
Here you go, click on the images to magnify and zoom them up to read them:
Now the P0337 fault you had previously may be an issue - the engine speed sensor as if that is sending duff info, then it will affect the injection. So although you have cleared some of those faults down - that doesn't mean they are gone and if / when the conditions arise again, the fault will come back.
craig lawtonawton
Ok mate so I dont know that much what would you say is my problem and what do I do to fix problem
- x 1056
Get it on live data and check:
Engine RPM, you want to see a minimum of 300rpm.
Check cam & crank synchronisation is at YES on cranking.
Check fuel pressure on crank, you want to be seeing at least 110bar on crank.
craig lawtonawton
Dont know how to do live data as not used this program I bought it off ebay
- x 6947
When you've run the Global Test, select the Siemens SID803 which is the Engine ECU on this vehicle. Look for this on the list of ECUs that come up. Select it and you should get a menu where you find a 'Parameters' button or similar. From there you should be able to pick and run some live tests.
