C4 vts
Wawpeyo
C4 vts
Unread post by Wawpeyo »
Good morning!
Anyone knows where is the vvt oil control valve on VF7**************[VIN obfuscated, can be read by forum staff]?
x 6947
Re: C4 vts
The oil circuit valve is (13) if that's what you are after.
Wawpeyo
Re: C4 vts
Should not be in the admission side?
Nothing on where 13 is pointed
Wawpeyo
Re: C4 vts
Its is the camshaft oil control valve, that thing on 13 does not look a solenoid at all
x 6947
Re: C4 vts
Here - Solenoid valve controlling the camshaft dephaser (21):
Wawpeyo
Re: C4 vts
Thats the one, lets go and look for it, thanks
Wawpeyo
Re: C4 vts
Any special instructions to remove it? Hardly can see it, it turns 1/8 but not moving out a mm
Wawpeyo
Re: C4 vts
Well came out at the end, bit of debris on the screen, do you think is any actuator test for it? I was looking around diagbox and cant find it
x 6947
Re: C4 vts
I don't so - it's just a control solenoid.
Wawpeyo
Re: C4 vts
Ok, i tried myself, but no luck, so lets ask the experts.
Antipollution fault.
When you start it rough as fk and the fist screen of faults come on, cleared and the s3cond screen of faults came, the fan for some reason starts going after 5 minutes running.i believe just when the antipollution fault comes on
For some reason , i cleared the faults yesterday and run like silk just the inlet dephaser fault on , but not very much noticeable.
Today after cleaned that solenoid and changed the oil just in case, well all came back and now
Wawpeyo
Re: C4 vts
Sorted, thanks for all the help
