DPF and engine warning light P2562
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: DPF
Your Berlingo doesn't have a separate relay showing on this engine (normally in the Fan Cowling Assembly), which means the function is integrated into the a relay within the Engine Fusebox - and these are generally non-serviceable.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: DPF
Fuse boxes? - No
Engine FuseBox - item (5)
Old part: 9807028880
Replacement (Updated) Part: 9807028780
- (Donor 2017)
- My Cars: Citroen C5 2.0 Hdi 2003
- x 39
Re: DPF
When are the fans running? Whilst driving, or when you stop? If when you've stopped, for how long after? To flatten a healthy battery the fan would probably need to run for best part of an hour.
Are you using the air con?
How hot is the cabin blower on highest heat?
Have you checked the coolant level?
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
Re: DPF
coolant is fine, not using air con, never checked how hot cabin fan are but it does get warm, fans are probably on when driving but stay on after switching off, they can run for 6/7 mins but do run very regular, whatever the fault is, could it trigger the fans to run at any time- middle of the night for example. didnt use the van for 2 or 3 days last week (lockdown) and battery was too flat to turn it over. i do get an occasional error code p2562 (i think).411514 wrote: ↑02 Nov 2020, 16:13When are the fans running? Whilst driving, or when you stop? If when you've stopped, for how long after? To flatten a healthy battery the fan would probably need to run for best part of an hour.
- (Donor 2017)
- x 39
Re: DPF
Check how hot the blower is on full heat. If excessively hot, that might indicate a genuine overheating issue, e.g. dodgy thermostat. If cool, may indicate airlock in coolant, which may interfere with temp sensor, although this seems unlikely.
I'd be very surprised if fan is turning on overnight.
Sounds like you may have another issue re flattening battery. Did the first occurrence of fan running and battery flattening coincide? They don't sound related to me. If battery is OK, I'd suspect some consumer is staying on overnight - that's quite a high drain, perhaps dodgy alternator rectifier.
Ideally you'd hook it up to a Lexia, which will presumably be able to tell you the temperature reading.
Does your car have a temperature gauge on dash? If that isn't dropping when the fans are on, something sounds genuinely wrong with cooling, and my guess in that case would be thermostat.
I'd probably replace thermostat next - that'l give you chance to bleed coolant as well. Thermostat and coolant probably won't cost much more than £30 together, and coolant is good maintenance anyway.
Edit: and another thought, if you do suspect actual overheating, have a think about the coolant pump - can you see any leakage? When is timing belt/pump next due a change - if it's soon bring it forward to rule it out now, if not soon don't bother, because too much hassle for unlikely suspect.
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
Re: DPF
will check the blower temp tomorrow, there is a temp gauge which dont show a high reading when the fans run, fans have been running for a while before the battery went flat (less than a year old) 14.2v at the battery when idling, anyone in swansea area with a lexia?will look into a thermostat next.
- (Donor 2017)
- x 39
Re: DPF
From what you say, battery flattening and fans running seem unconnected, so plan on tackling them separately.
On the battery flattening point, to test whether it is duff battery or a consumer staying on, disconnect battery next time you are parked up for same amount of time as previously (did you say 2/3 days). If engine doesn't then start when reconnected, then battery is duff. Easy fix by replacing battery, but be mindful that there may be a reason why battery duff, e.g. discharged repeatedly by consumer.
If engine does start, then there is a consumer somewhere. Aftermarket headunit and alternator will be main suspects.
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
Re: DPF
Temp sensor changed but still fans are running, is there a way of testing the relay even though it's built in?GiveMeABreak wrote: ↑28 Oct 2020, 11:37These are the fan speed triggering temperatures for your vehicle. Bear in mind if your Air Conditioning is switched on, the low speed fan will kick in regardless - so switch the A/C off before testing. Taking that into mind, if the fan is coming on (without air conditioning active) earlier than these temperatures below then something is triggering it and it could be the temperature sensor / relay / short etc.
Description manual gearbox Temperature threshold (For illumination of the "STOP" warning light on the instrument panel) 118 °C Temperature threshold (For extinguishing the "STOP" warning light on the instrument panel) 115 °C Triggering threshold (Fan unit at slow speed) 96 °C Triggering threshold (Fan unit at high speed) 105 °C Temperature (Air conditioning cut-off) Negative external temperatures
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: DPF
No, not with the ones incorporated into the engine ECU AFAIK.
Fault P2562 relates to Turbo Charger Position out of reference values yy 20% or more, causing a lack of power.
Back to the cooling issue - if the coolant housing sensor is shot - it will provide the wrong info and the engine ECU will keep operating the fan as it thinks the engine is too hot (including after you switch off the ignition). Here's an explanation:
Cooling Fan Regulation Relevant to Engine Temperature
For cooling of the condenser, the B.R.A.C. function (Air Conditioning Need For Cooling) supplies the F.R.I.C. function (Cooling Function Integrated into the Engine ECU) with a reference speed in accordance with the pressure of the air conditioning circuit.
The linear pressure sensor of the refrigerant fluid fitted on the condenser supplies a voltage proportional to the pressure in the air conditioning circuit and transmit this information to the built-in Systems Interface on the CAN IS network.
The engine fuse box sends a speed reference value to the engine management ECU making it possible to control the slow speed or fast speed of the cooling fan unit.
Post Ventilation
When the engine stops, the engine ECU orders post-cooling, if the measured water temperature exceeds a programmed threshold.
The fan unit cannot be started in the following cases:
The duration of the post-cooling is 6 minutes.
Observations
So if your post cooling operation is longer than 6 minutes you have a problem - and this may be why your battery is flattening.
If your Coolant Temperature Sensor in the outlet tank is shot, then as said it will provide incorrect temperature readings resulting in the fan engaging in post-cooling operation more frequently - again draining your battery.
So I would consider the outlet tank / sensor first.
- Two temperature intervals allow the cooling fan to operate either at slow or at fast speed (Control in relation to the engine coolant temperature). See my last diagram showing triggering temperatures.
- The engine coolant temperature sensor, installed on the coolant outlet housing, informs the engine ECU of the temperature of the engine coolant.
Key "a" Cooling fan unit speeds triggering thresholds. "b" Fan unit speeds untriggering limits. "A" Fan assembly low speed. "B" Cooling fan unit fast speed. "P" Pressure (in bars). |
- Operation in power latch (*)
- Switching off of the engine ECU electronics
- Engine starting phase
Observations
