Having just fixed my high level brake light (broken wire) I'm now on to the next job.
I assume these lights in the tailgate are controlled by the body computer? Should I be plugging in before hunting for breaks in wires?
I have reverse and fog but no sidelights or number plate lights.
C5 X7 tourer tailgate and number plate lights not working
onza100
onza100
Re: C5 X7 tourer tailgate and number plate lights not working
Update the sidelights have blown bulbs. Changed but still not working
onza100
This is the fault. Broken wire somewhere?
- x 1056
Is is just the sidelights on the actual tailgate lid? Are the outer ones on the body working ok? If this is the case & you have replaced the bulbs then this is almost certainly a broken wire in the body to tailgate harness.
If you have no rear side lights at all i would look at the fuses next.
onza100
Thanks it did turn out to be broken wires. I was overthinking it.
- x 6946
This area in your last picture is a well known issue and the usual culprit.
onza100
Hopefully this thread will help someone in the future.
