HI All,
We have a range of questions but will publish them in separate topics if thats ok.
We have quite few missing screws in our floor trims. The screw we measured is 4mm x 30mm.
Does anyone knows if most floor screws are the above dimensions and where could we buy them from?
Should the screws be covered with plastic covers/caps?
Is there a diagram for the cab floor screws?
We don't know the correct name for the thick insulated flooring panels. Due being damaged, are they availble only from a main dealer?
Citroen Relay Cab Floor Trim / Panel screws
- x 1056
Re: Citroen Relay Cab Floor Trim / Panel screws
Best to post a pic of what your looking for & a pic of where it goes. There may be more than one type of screw holding things down.
As for the cab flooring, you will be able to buy it from Citroen but I suspect it wont be cheap.
Have you checked with breakers?
desirex
Thank you for your reply. We haven't checked with the breakers but will do now, thanks.wheeler wrote: 25 Oct 2020, 13:40 Best to post a pic of what your looking for & a pic of where it goes. There may be more than one type of screw holding things down.
What we found on the internet is either 3.5mm or 4.2mm in diameter. Not sure which ones to choose.
We have attached the photos.
- x 1056
There are 2 different types of screws used, Citroen part nos. 6924A5 & 6924A7.
If it was me I'd just go into B&Q and match the screw up to something similar as it's only for holding some trims down.
desirex
We tried some regular screws 4mm. Bit tight but seem to work for the time being. We might spray them blackwheeler wrote: 26 Oct 2020, 08:08 There are 2 different types of screws used, Citroen part nos. 6924A5 & 6924A7.
Many thanks for the advice.
