Citroen Relay X244 Turns Over but Won't Start
Tom_W
Unread post by Tom_W »
Hi All,
I'm having trouble with my 2003 Relay 2.2 HDI (and I'm fairly confident I caused it #-o).
A few days ago I replaced the alternator and since then it'll turn over but it won't start. Before I swapped the alternator I disconnected the battery (at the negative terminal) & reattached it again once finished but but since then it just spins over and never catches. It's worth mentioning that before I started working on it I needed to move the van on to the drive and it fired up like normal.
I've checked the alternator is in correctly and the belt is ok, I've also checked the fuses under the bonnet, cleaned the battery terminal & fully charged the battery. I've checked the fuel cut off switch (for no real reason other than clutching at straws) & attempted a BSI reset (although this may have not been done correctly, the info I found online all had a step for the remote central locking key & the van doesn't have it?!?).
I can hear what I think is the fuel tank pump priming when the ignition is turned on and It turns over nice and fast but there is nothing from the exhaust (no puffs of smoke, no smell etc.) it feels like the immobiliser is on but the light on the dash goes off after a few seconds as it normally would.
At this point I'm fairly well out of ideas so any help would be very gratefully received.
x 1056
Re: Citroen Relay X244 Turns Over but Won't Start
Unread post by wheeler »
First things first, go back over the job you done & check you have not left anything unplugged or plugged back in the wrong place. Did you disconnect anything on the HP fuel pump to get access?
There is no BSI on this van. If the padlock light comes on & goes off as normal then i would say the immobiliser is working as it should.
Tom_W
Thanks wheeler, I'll double check and report back... at least it's not raining yet today.
Tom_W
So, mystery solved... it turns out I'd managed pull the wire out of the injector pump!
I just took one of the intercooler pipes off and spotted the plug dangling right next to the pump!
That's a lesson learned.
Thanks again Wheeler!
x 3298
Oops! Still, at least it was something simple, and did not cost much more than a bit of hassle and time.
Tom_W
Yeah, I'm currently somewhere between pleased and embarrassed! Maybe a tad closer to pleased!
