Hi folks, hope you are all well!
My reverse lights have stopped working and the bulbs are ok, my next checks are the fuses then the switch.
Can anyone advise the locations of these please or anything else to check?
Tam
2007 Xsara Picasso 1.6 HDI 92 BHP
Vin if needed VF7**************[VIN obfuscated, can be read by forum staff]
Xsara Picasso reversing lights problem
- My Cars: 2007 Xsara Picasso 1.6 hdi
2003 Xsara Picasso 1.6 8v
Wish I still had my 1996 ZX 1.9D - x 10
Re: Xsara Picasso reversing lights problem
The switches are a fairly common failure, depending on which gearbox is fitted it will either be right on the top of the gearbox casing or slightly to the front, it has a 2 pin plug.
Disconnect the plug & bridge the 2 terminals with a piece of wire & turn the ignition on, if the lights come on the switch is faulty.
Thanks for this! Just updated my OP with car details which would have been handy. It's BE4-5L MANUAL GEARBOXwheeler wrote: ↑19 Oct 2020, 19:27 The switches are a fairly common failure, depending on which gearbox is fitted it will either be right on the top of the gearbox casing or slightly to the front, it has a 2 pin plug.
The switch should be located here.
Cant remember the socket size off hand to remove it but the socket needs to be quite thin walled as the recess it's in is quite narrow.
Switch tested and changed-Worked a treat, thanks for your help!
