Audio and satnav
Cris73
Audio and satnav
Hi everyone I've just bought a c5 on a 07 1.6hdi, the radio and satnav don't work, the screen lights up and says citroen then it goes blank and nothing seems to work. Anybody know what's going on because I really haven't a clue lol Thanks
- x 6963
Re: Audio and satnav
It may help if we knew what system you have. Pop your VIN (auto masked by software) up so I can see what you system you have fitted.
Cris73
Sorry. My vin is VF7**************[VIN obfuscated, can be read by forum staff].
- x 6963
Ok so on your MK II C5 it will be the older RT4 system:
Do you have the original Software CD with the car? If not ask your Citroen dealer to order you one on CD. The last version available is V8.11 (part: 9679242580) and see if that will fix the issue. They only cost a few quid to order so have not got anything to loose. They are not made anymore, so if the software won't fix it, try a BSI reset using this procedure:
BSI Reset / Battery Disconnect / Reconnect Procedure
Sometimes a complete system power down can reset the system as the power on the units is retained when the ignition is off.
Follow the instructions exactly at the relevant parts (ignore the bits for electric tailgates and Stop Start / Keyless vehicles). Pay attention to the timings and do not fiddle with any switches or open doors during the timings.
Cris73
Thank you for your help I will get hold of citroen and get a disc of them and see if it works then I will work my way through the other problems it's got lol.
- x 6963
Try the BSI reset first - as that costs nothing apart from time. Then you can try and update the firmware if that doesn't work.
Cris73
I've tried the reset but the screen still says Citroën, so I will get hold of th cd and fingers crossed it will work
- x 6963
It sounds like a boot problem - and this may be as a result of internal corruption / chip problem. You have nothing to loose trying to boot from the CD and see if that will restore the system, but failing that, it will likely need repairing or replacing.
Cris73
I've been on line and looked for the same stereo system and I manged to find one for £180 with a screen.
- x 6963
Your screen should be fine and will save having to remove the fascia. Just make sure you code the new unit with your VIN and make sure you disconnect the battery before you remove / install the new one.
Also, you may have to configure the new unit to match your factory-fitted options.
Cris73
Thank you for your help. I will make sure I do everything properly because I would like all this to work again
- x 6963
Here's the battery disconnect / reconnect procedure for you:
Cris73
I did that this afternoon but it's still just says citroen on the screen.
Cris73
Right I’ve got hold of Citroen near me and they wasn’t any help at all they also said they don’t have any cds. Now I’m not sure what to do, if I could find someone with lexia where I live that would be a big help.
Onlinemyglaren
- x 5626
Have a look in the Lexia Locations thread - there is a list of members there and a map link at the bottom showing locations.
Lexia Locations
Lexia Locations
