Hi my Berlingo 5d petrol engine stalled on my drive when I got it going it sounded like a tank. The RAC guy came and checked the fuel which was clean. The oil is fine. It’s done 96k and is 2005 reg and has run as sweet as a nut. Could it have dropped a valve? Could this be its death rattle. Any advice would be welcome. I have no experience and could tell you where the plugs are if this could be a problem. It’s the harsh rattle that has got me worried.
Thanks in advance
Engine rattle and timing out
- x 6945
Re: Engine rattle and timing out
If it sounds like a loud rasping noise, check the turbo air hose - even a slight hole / split can make this sound.
OnlinePaul-R
- x 1938
Was the RAC guy there when the engine was running? he should surely know what it sounds like.
- x 1053
No turbo on a 2005 Petrol Berlingo.GiveMeABreak wrote: 24 Sep 2020, 19:38 If it sounds like a loud rasping noise, check the turbo air hose - even a slight hole / split can make this sound.
Any warning lights or fault codes? What exact engine do you have. They certainly aint known for dropping valves. First port of call would probably be a compression test and/or borescope into the combustion chamber. You can buy a half decent endoscope that connects to a laptop for under £20.
- x 6945
Of course - didn't see the petrol reference.
