Xsara Picasso -05 interior light not working as expected
lucafaia
Unread post by lucafaia »
Interior light should go ON when door is opened. In my car the the light works only when I turn the key to have the electrics ON. Solution?
x 1056
Re: Xsara Picasso -05 interior light not working as expected
Unread post by wheeler »
Is everything else working as expected? Is the clock keeping its time ok? Has anyone been messing about in the fusebox?
The interior light works like this when the shunt fuse is in the wrong position.
captainkephart
x 8
Unread post by captainkephart »
Hi Lucafaia,
There is a switch on the interior light above the mirror.
Three positions I think:
- Interior always off,
- On when doors open,
- Manual on.
Have you checked that?
Ciao, Captain K
The secret of happiness is freedom - and the secret of freedom is courage ...
lucafaia
captainkephart wrote: 29 Aug 2020, 10:39 Hi Lucafaia,
- Manual on.
Ciao, Captain K
That was the case In older models. 2005 model does not have that switch
lucafaia
wheeler wrote: 27 Aug 2020, 21:39 Is everything else working as expected? Is the clock keeping its time ok? Has anyone been messing about in the fusebox?
Clock keeps its time. Once upon a time I smelled smoke In the fusebox. I disassembled it and checked the "motherboard" but did not find anything that looks bad. After that episode however, the rear lid hasnt opened anymore. I dont remember if interior light worked before that episode bcs I had just bought the car and it was midsummer In Finland (gets never dark :))
Everything else works fine. Which position the shunt fuse should be? In my car it is in the upper slot.
x 1056
Best to post a picture to confirm if its in the right place, Later full CAN citroens have it marked as Park/Client but i dont think the picasso will have this as its not full CAN.
lucafaia
wheeler wrote: 29 Aug 2020, 11:35 Best to post a picture to confirm if its in the right place, Later full CAN citroens have it marked as Park/Client but i dont think the picasso will have this as its not full CAN.
Same position as In this one: the slots are not marked, just FSI written beside https://images.app.goo.gl/LhK7ph86QG5xnGX89
x 3298
The Shunt fuse is normally in the cabin fuse box. It SHOULD have one. I had a 54 reg Picasso as a company car, and once it started doing weird things. The RAC guy swapped the shunt fuse to the opposite position for a couple of minutes and then swapped it back the the car was fine.
x 1056
lucafaia wrote: 29 Aug 2020, 12:37
That looks correct then.
lucafaia
Hell Razor5543 wrote: 29 Aug 2020, 12:59 I had a 54 reg Picasso as a company car, and once it started doing weird things. The RAC guy swapped the shunt fuse to the opposite position for a couple of minutes and then swapped it back the the car was fine.
That sounds like worth to try. Unfortunately it is impossible - the other slot is different size, the fuse like thing does not fit there.
Edit, noticed that a normal fuse fits in other slot, tried the trick with normal fuse but no luck
x 3298
IF my memory is correct (and I am not certain of this) the SHUNT fuse has three 'slots', and it always uses two of them. If the slots are how I remember, they are like - - -. In one position you would have something like XXX - (the XXX is the shunt), while in the other position it would be - XXX. As I said, I am NOT certain of this, but it could be worth looking.
x 1056
On the above type of BSI there is only one location the shunt will physically fit, when it leaves the factory a regular 30 amp fuse is fitted in the lower position which is removed at PDI & replaced with the shunt in the upper position.
On later full CAN cars the shunt can be moved across & fitted in either position.
lucafaia
wheeler wrote: 29 Aug 2020, 16:38 On the above type of BSI there is only one location the shunt will physically fit, when it leaves the factory a regular 30 amp fuse is fitted in the lower position which is removed at PDI & replaced with the shunt in the upper position.
That seems to make sense.
Just thinking - I bought Lexia system, having not yet studied / installed it. But could it include some tools for maybe re-configure/fix the interior light behaviour?
x 6948
There won't be anything to configure for that.
