Where is the Fuel Filter !!!!!!!!!!!!!!!!!!
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi me again lol
Just a quick question that has got me beat :(
Vehicle in question is :
207 1.4 59 plate 3 door
Question is where the heck is the fuel filter located, there must be one right :? :? :? :? :?
Vin number is VF3**************[VIN obfuscated, can be read by forum staff].
And yes it is my lads car
Colin
x 1056
Re: Where is the Fuel Filter !!!!!!!!!!!!!!!!!!
Unread post by wheeler »
Is it a petrol? Some dont have a normally replaceable filter, just a strainer in the tank. If there is no return line on the fuel rail there won’t be a filter.
x 6954
This model (TU3E5) has an integral fuel filter within the gauge / pump module.
admiral51
(Donor 2026)
x 391
Thanks guys I will stop looking for one
Oldpug
x 93
Unread post by Oldpug »
Peugeot stopped fitting external replaceable fuel filters on petrol models about 18 years ago.
x 6954
Actually they still do have them on petrol engines across the PSA range - it depends on the model and engine. Some will have the fuel filter inside the gauge and others will have an exterior filter as you can see below, item (9):
Where fitted, it's usually hidden as it's on the fuel line exterior to the fuel tank and not immediately visible.
This is from an EP6CDT Prince Engine fitted to the C5 X7, but there are loads of other models.
Oldpug
x 93
The “find the fuel filter” argument has been going on for years. Yes, you will find it listed on parts pages, but I’ve never found one on UK models? I think you will find them on African, Asian and other regions where fuel can be not so clean.
x 6954
That's quite likely, I mentioned it because we do have a large international membership, so would be applicable to others following the thread.
