Xsara Picasso abs
Mole 1959
Xsara Picasso abs
Help needed please when I start the car after a couple of seconds abs and esp fault lights come on I've checked wheel sensors and replaced two, still no change what else do I need to look at thanks in advance
- x 1056
Re: Xsara Picasso abs
What fault codes are you getting?
Mole 1959
Only got a simple code reader so it's not showing me any codes so pulling my hair out and I've not much left
- x 1056
Why would you replace wheel speed sensors and you haven’t read fault codes from the ABS system?
Your wasting your time (and money) replacing parts without checking ABS fautls.
Are the brake lights operating correctly?
OnlineHell Razor5543
- x 3283
Before you do any more work on the car PLEASE arrange for it to be read with a proper diagnostics tool. You will need access to a Lexia system. Fortunately there are Forum members who have such equipment and are willing to help (although, with the COVID 19 situation, this cannot happen for a while). Here is the link to find who is closest to you;
https://www.frenchcarforum.co.uk/forum/ ... hp?t=56452
However, not all members are active, so you may have to contact a few to get a reply.
Mole 1959
Replaced two because one had something trapped and damaged the end so inards were exposed the other I managed to brake the mounting lug ofwheeler wrote: 05 Apr 2020, 19:14 Why would you replace wheel speed sensors and you haven’t read fault codes from the ABS system?
Mole 1959
Re: Lexia 3
This has proberly asked before will lexia 3 run on Windows 10 64bit if so how
- x 6963
If you are referring to the encapsulated Lexia software then no, not natively. Lexia and PP2000 (for Peugeot) are separate software applications incorporated in and launched from the main Diagbox application and are written in 16 bit code which cannot run natively under a 64bit operating system. The only way to get it running on a 64 bit OS is to setup a virtual machine with a 32 bit OS, install and run it from there. BUt a VM can introduce additional problems with comms ports like USB if not configured correctly and does make troubleshooting more of a problem.
Mole 1959
Thanks for the help so, picked up a Windows seven laptop and installed program took a bit to get it running ran diagnostic but for some reason would not communicate with abs ecu can't figure out why any one got any ideas
- x 1056
Does it communicate with everything else? If so then this may be the problem.
If everything else is talking to lexia you need to start checking power supplies to the ABS ecu.
Mole 1959
Yes it seems to so will have to check the surpply to abs think I should have got a decent code reader as these lexia seem to be a pain to set up unless it's just me
- x 6963
You really won't get better than a Lexia for PSA as they are near dealer-level devices. The issue is that they have been 'modified' for Joe public and mechanics to use and are not supported by PSA as they are not supposed to be available to us - so one has to expect quirks getting them to install. The problems are usually not having a suitable laptop with the required specs or the wrong controller interface setup / or installation errors / faulty instructions.
Mole 1959
Success lexia now reading all ecu, would read most but not abs found that most of the ecu could be read of first turn of the key but would only read abs and injection with ignition on problem solved.
THANKS FOR ALL YOUR HELP.
- x 6963
Some systems are not activated unless the ignition is on as you've just found - you should always test it with the ignition on.
- x 1056
So what was the ABS faults then?
Some A/C systems even need the engine running to get communication.
