C4 VTS - Adjusting power steering pump assistance
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I want to decrease the amount of assistance of the power steering pump, to make the steering less vague . Does any one have the wiring scheme to the power steering pump ? Has anyone done it ?
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 6955
Re: C4 VTS - Adjusting power steering pump assistance
That's not wise - it's set up by default to provide variable assistance based on the following:
  • The speed of rotation of the steering wheel
  • The vehicle speed
  • The temperature of the steering fluid
Obviously the assistance is reduced the faster the car is travelling. The system is computer controlled and you cannot change the system.
lancia58
(Donor 2022)
x 8
Marc,
Do you have the wiring scheme to the power string pump ?
x 6955
As I said - it takes inputs from your steering wheel angle sensor, the ESP system and is controlled by computer within the Power Steering ECU.
