C4 heater/air con not working
petef
- x 11
Re: C4 heater/air con not working
I have recently been back to the auto electrician who gave me the 'splicing' solution, and told him he is now an FCF star with over 20000 hits. A very happy man, although he did point out it hadn't made him rich.......
- x 5675
Just stuck in a loop somehow. Binned that as it was less than useless.GiveMeABreak wrote: 21 Nov 2019, 13:26 I can't see it Steve... That link goes to a list of user posts - and the first one links back here??? The others are about heated seats and Diagbox threads - did you copy the wrong link?
Arthuros-+
Problem solved.
Had to take it to the car electrician who replaced the plug and the green relay in the engine compartment by the fuse box and a connector under the glovebox that was heating up. Hope it helps someone with similar problem.
phrozenballs
Hi guys I also have a dreaded heating blower failer and was looking for a little guidance if possible my car is a 1.6 hdi 2009 c4 coupe VTR plus with approx 180000 on the clock . VIN VF7**************[VIN obfuscated, can be read by forum staff]
Ok the cars served me well with many trips from the uk to Spain under its belt with only a few Dpf faults that have been circumvented
I was driving down the motorway and heard a plink come from the passenger side of the car , a bit like a very small stone hitting the door when the blowers went off , I have all the lights for the air con , circulation etc and when driving you can feel heat present at the vents but 1 through to 4 on the fan speed selector does work at all .
I’ve checked all of the fuses both in the glove and under the bonnet
I’ve tried an ecu reset (unhooked batt over night)
I tried the bridge fix in this thread
I’m guessing the next things for me to check would be the actual fan and a resistor that’s attached to the unit and I believe this is under the glovebox passenger side , am I correct in think this please
phrozenballs
Mine is fixed now to reassemble the glovebox ... what a pain in the butt . Turned out to be the resistor not sure how to add images otherwise I’d of posted some pics up . Cost of a few grams of solder thanks too all of the usfull info in this thread
- x 6947
I'm glad it's working - the subject has been covered extensively on this and other threads, so I didn't want to repeat what has already been put up.
dzoni
hi, I seem to have the same problem with ac as some have commented be4 me, this is a peugeot 307 phase2 with auto AC same as a c4, tried replacing the hedgehog blower regulator but the same problem occurred, problem is below, any known solutions? ty
- x 6947
Is this your actual vehicle in the video? I see that has an Android system that has been retro-fitted. This won't be the first time I have heard of these interring with the vehicle's systems if not done correctly. It could be a CAN problem on the vehicle network.
You may also have a faulty climate control panel. But really you will need Diagbox on it to get a diagnostic. There are lots of actuator tests you can run to check the various button pushes and the system overall. That may give you a clue.
dzoni
yeah bought it with the android already on it, with the ac problem as well by the previous owner, so diagbox check is a must?
Should also say that when driving a few km and stopping and than starting the engine on it all works, all buttons everything, ac, heater a OK.
- x 3298
I would say that that is a definite YES!
- x 6947
I think so, because otherwise you aren't really going to know where the problem lies.dzoni wrote: 12 Jul 2020, 15:45 yeah bought it with the android already on it, with the ac problem as well by the previous owner, so diagbox check is a must?
Several possible issues:
- the wrong blower motor control module was fitted;
- the blower control module part number was right, but the quality of the module was poor if not an original or decent make (Valeo, Behr for example).
- wiring issue with the multiplexed network (maybe, or maybe not caused by the wiring in of the Android)
- faulty A/C climate control panel
- blower fan unit bearings may be seizing due to water / condensation. This then means there is insufficient power to start the blower motor (as these are designed to start off slowly, then increase in speed. Some people have bridged the blower motor directly to bypass the blower control module and provide full power to get it going again. But this is only a temporary fix and ideally if this is the issue it will need replacing as the rust will get worse.
chaznugent
my c4 gp 2008 had the water leak issue that's now fixed but my heaters stopped working. my heater is fine the resister is fine the problem i have the wired plug that goes into resister has melted can i buy a new plug or what do i do thanks
- x 1496
Welcome along! You can probably buy the plug - but it will come with miles of harness attached and cost ££££!!! Best bet is to find a scrapyard with one in stock (or e-bay) and cut the plug off, then solder it on to your car.
chaznugent
ive seen a c4 picasso heater blower resistor wiring repair loom 6441ce is this the one im so thick with things like this lolRichardW wrote: 27 Nov 2020, 12:13 Welcome along! You can probably buy the plug - but it will come with miles of harness attached and cost ££££!!! Best bet is to find a scrapyard with one in stock (or e-bay) and cut the plug off, then solder it on to your car.
C4matt
- New User
Location of 2004 - 2010 Citroen C4 heater blower and heater resistor
I couldn’t seek the components out that easily - hope this helps.
