2009 Peugeot 308 1.6HDI DV6TED
Scanned codes P1462 & P2299
When lightly press accelerator from coasting there is a flat spot were it hesitates and then goes. That flat spot also sometimes happens when driving along, it feels like it dies for a sec or two then picks up. Live data shows EGR throttle electrovalve invalid reading at idle, also invalid readings sometimes when driving along. Is the P1462 linked to EGR throttle electrovalve and where is the EGR throttle? In the dossier?
Flat spots & P1462
moizeau
- x 429
Re: Flat spots & P1462
Do an actuator test on the egr to confirm. Also unplug the MAF and go for a spin. The hesitation / flat spot sounds similar to mine, also mine didn't like 3000 rpms under load on 4th or 5th, and felt a bit flat.
Have a read through this,
https://www.frenchcarforum.co.uk/forum/ ... 3&start=45
the flat spot bit is page 4 about 1/2 way down.
Pete
pauljordanie
Thanks, I did actuator test and EGR valve clicks.
pauljordanie
I've disconnected the MAF sensor and the problems gone. Except MIL and depolution warning as expected. Can I take it that MAF needs replacing?
- x 5674
You could try cleaning the MAF - handle it very carefully and don't touch the fine wires with anything, just use a few shots of a spray cleaner - I used carburettor cleaner that worked perfectly but there are dedicated MAF cleaners now.
Three years since I did mine and it is still OK.
moizeau
- x 429
pauljordanie
I took the MAF off and cleaned. Put back on and problem comes back. Luckily my wife has a C4 GP with same engine so I swapped MAF over. Problem is still there. So I think the MAF is good and the info its giving to ECU is effecting something else.....
- x 1943
Almost more importantly, is the problem not there on your wife's car with your MAF?pauljordanie wrote: 05 Jul 2020, 10:58Luckily my wife has a C4 GP with same engine so I swapped MAF over. Problem is still there.
pauljordanie
Swapped suspect MAF onto wife's car. Problem isn't there so pit back on 308...since the code was associated with EGR throttle electrovalve I disconnected the electrical connector to that throttle on the dosser with the original MAF fitted. EML off problem not there....
Drove about 30 miles and EML came on but car runs ok.
moizeau
- x 429
Mine was a dirty plug connector on the harness, not the actual MAF. I'm not sure of the pinouts to test the plug but I'm sure someone who knows will be along.
Pete
