Hi guys,
I drive an Citroen C5 2010 and got this warning today, Suspension faulty max speed 90km/h.
I seen also that the front of the car is very low againt the back.
What do to do?
Br
Ezmir
Citroen C5 2010 Suspension Faulty
EDC5
- x 130
Re: Citroen C5 2010 Suspension Faulty
Can you raise the height manually using the buttons in the car?
Ezmir
No.. it dosnt work..
I found the fuse for the hydraulic pump. I put a new fuse and the car raised at the lowest level.
It can maybe be that the pump is problem?
EDC5
- x 130
It is possible that your pump has become contaminated with oil and is causing excessive current to be drawn.
This happened to me and I've got details in these threads here:
viewtopic.php?p=579189
And my repair:
viewtopic.php?p=581404
And my repair:
Ezmir
the problem is that the fuse dosnt blow.
I would like to messure the current on the pump to se if somethins happen with ih or if its dead.
Ezmir
i hope that i checked the right fuse. it is F13 i think ?
EDC5
- x 130
Sorry, I misread your post. I recall reading somewhere that there is a large transistor that activated the pump motor (located on the motor itself). If you are lucky then this could be the problem rather than the entire pump.
Ezmir
Shouldnt it be a relay that activates the pump. But it should work manually to raise it up without the relay but can be that they use the same relay for manually and automatic raising
Hmm very strange
Hmm very strange
EDC5
- x 130
Yes from what I remember it is a solid state relay (transistor) that activates the pump. It is signalled from either the BHI or BSI as far as I am aware.
On the pump you can identify it as it has one thick wire and one thin wire, these are the power and signal wires respectively.
Ezmir
Where is the pump located on the car, can i see it easly or do i need to remove a lot of things first?
EDC5
- x 130
If you look at those two posts I linked, you should gain a lot of info.
petef
- x 11
Presumably the LDS level was checked? , a leak in the system will bring up the speed warning. Happened to me when the steering rack was on the way out and started leaking. And I was 300 miles from home .....
Reason: Corrected to LDS
- x 3302
LHS? Surely you mean LDS (and I am NOT calling you Shirley!)?petef wrote: 23 Jun 2020, 14:00 Presumably the LHS level was checked? , a leak in the system will bring up the speed warning. Happened to me when the steering rack was on the way out and started leaking. And I was 300 miles from home .....
petef
- x 11
Oops LDS it is, I remenbered LHM is what goes in the Xantia ......LHS was early DS's as I am remembering now. Old age I suppose
Ezmir
Hmm.. i seen that i have a lackage on the right suspension. Soo i thiught that the LDS level was low. I purchased 1 liter LDS oil..
Started the car, noothing happenes:((
