How can I find out what I have here?
Indy500
Re: How can I find out what I have here?
That was easy enough! Have donated for your hard work and thank you for any information I can get. Super job!
Indy500
The sticker in the cab is an svtech plate. It just feels wrong all over though. We removed a 100kg Honda generator from the van and it's still 300kg over.
- x 6956
Ok, leave it with me and I'll dig out what I have.
- x 6956
Ok, so these are the official weights for this vehicle body type (Cab)
(?): These weights may vary depending on the equipment
Bear in mind there are a multitude of options for these vans, they were supplies in all sorts of chassis designs, length, glazing and panel options. They were available as cabs, double cabs, vans etc.
So the above is what I have for your engine and cab type as listed. But the van could of been modified and hence why it may have a separate plate on to reflect the modifications from a custom coach builder.
But parts wise, this shouldn't come into it, assuming nothing mechanically has been altered on it. We can get the available PSA part numbers you may need from the VIN.
| Cab chassis 18Q average wheelbase | |
| Type code | 232K92 |
| ENGINE | T8ADJ5T |
| Unladen weight in running order (?) | 1635 |
| - on the front axle | 1255 |
| - on the rear axle | 380 |
| Gross vehicle weight (GVW) | 3500 |
| Maximum admissible load | |
| - on the front axle | 1850 |
| - on the rear axle | 2120 |
| Gross train weight | 5100 |
| Weight of the trailer within the limits of GVW | |
| Trailer without brakes | 750 |
| Trailer with brakes | 1600 |
| Payload (including the driver) | 1865 |
Indy500
Hi there, donation sorted.
Could I have any weights data please. I need some part numbers for the clutch cable and speedo cable too if at all possible. Thank yoooou for your help.
Indy500
Sorry... I can see more info now I have posted again. Your post was missing. Thank ye very much.
- x 6956
The Clutch Cable (5) was either part 2150T8 for the BVM ME Gearbox or 2150L3 for the BVM MG5T Gearbox (Long 1734)
Both these parts showing as no longer available from Citroen.
The Speedo cable (2) was part 6123J8 - again no longer available. These are the other bits: (Click the images to magnify)
Anything marked as NFP are no longer available from Citroen.
That doesn't mean you can't get parts - just not from Citroen any longer. You at least have their part numbers and may be able to use these to help locate aftermarket substitutions.
The additional problem here is the age of the vehicle and at a time when a lot of the data was not transferred over to the electronic system. Another issue it would appear is the type of gearbox fitted - this may vary according to original specs, so they list all the compatible boxes - so I have put the diagrams and the part numbers up as I can't tell you exactly which box you have.
| Click on End Piece: Part Nos | Screw on End Piece: Part Nos |
- x 1346
It is very likely that this vehicle is fitted with the MG5 gearbox, as it was the only gearbox fitted to the Citroen XM with the 2.5TD engine, The ME gearbox would not have been strong enough.
Indy500
Epic info guys!! Off on a search for those bits now. Super job and I feel thoroughly helped!
- x 1750
The recently added mechanics' handbooks will help in identifying both engine and gearbox.
Indy500
Hi there, I need some part numbers for the three piece clutch on this van? Do I need to pay any more to find them out?
- x 6956
No, your contribution will cover you for up to 2 years. However, as I think I mentioned, data on this older engine is not as comprehensive as later models, as the part nunmbers are only internal PSA part numbers - which in a lot of cases here are no longer available given the age of the vehicle.
Click images to magnify
Here are the associated part numbers: The numbers on the table far left represent the numbers of the parts on the diagram.
- x 6956
As per your PM, here is the info for the Flywheel parts:
Anything else you need, let us know.
