Engine Coolant
- x 6946
Re: Engine Coolant
Yes, improvise is the middle word. I put the guide up as is, so that people can see what the Pros use. The important thing is getting the correct coolant, and degassing.
Gazzaman22
Re: Engine Coolant
Is this link dead for anyone else ?GiveMeABreak wrote: 22 Jun 2020, 12:46 See my illustrated post here: The procedure is exactly the same for your Picasso:
viewtopic.php?p=627831#p627831
- x 1941
Re: Engine Coolant
It's a valid link but it's in a members' only area. You need to make a contribution to the forum to be able to access this as it contains information that PSA now charges for.
- x 6946
Re: Engine Coolant
If you want to make a donation just click the link below. A min £10 donation will also allow us to provide you with part numbers and parts diagram information for up to 2 years.Gazzaman22 wrote: 07 Sep 2020, 13:14Is this link dead for anyone else ?GiveMeABreak wrote: 22 Jun 2020, 12:46 See my illustrated post here: The procedure is exactly the same for your Picasso:
Donate
Gazzaman22
Re: Engine Coolant
Very Happy to donate, Have got great help here in my time.GiveMeABreak wrote: 07 Sep 2020, 13:33If you want to make a donation just click the link below. A min £10 donation will also allow us to provide you with part numbers and parts diagram information for up to 2 years.Gazzaman22 wrote: 07 Sep 2020, 13:14Is this link dead for anyone else ?GiveMeABreak wrote: 22 Jun 2020, 12:46 See my illustrated post here: The procedure is exactly the same for your Picasso:
Donate
- x 6946
Re: Engine Coolant
Great, that's all sorted - the link should be available for you now.
Gazzaman22
Re: Engine Coolant
Cheers, Any "how to" coolant change for my engine handy marc? DV6TED4GiveMeABreak wrote: 08 Sep 2020, 10:29 Great, that's all sorted - the link should be available for you now.
bear in mind i wont have access to specialist tool.... I will have to improvise.
- x 6946
Re: Engine Coolant
Hi Gary
It is identical for your 1.6 HDi 110 engine, which is why I have not put up separate procedures as they are literally the same - exactly the same
