Time to change the coolant in the car.
Which-one/how do I choose the correct one?
Where is the cheapest place to get it?
How much do I need?
Cheers,
Andle
Picasso Xsara
1.6 HDI VTX
92 bhp
9HXC
DV6TED4
2007
80,000k
Manual Transmission
Engine Coolant
jsp
- x 12
Re: Engine Coolant
red one G12 spec. Unless someone put in Anti-gel. Then you need anti-gel.
My Citroens update:
http://www.frenchcarforum.co.uk/forum/v ... 14&t=50070
EDC5
- x 130
Re: Engine Coolant
I think the official Citroen recommendation is Glysantin G33.
I used TOTAL Glacelf in mine when I changed the coolant. It's a similar glycol-based OAT antifreeze coolant. Not sure how important it is really but I'd always replace it with a chemically similar antifreeze in case there is a reaction with any residual coolant were you to change to a non-OAT coolant.
- x 3566
Re: Engine Coolant
There's a myriad of lubricant / coolant selectors available from the major oil companies and parts suppliers. Run your cars reg number through one of them to see what they say.
Here's a couple of examples:
https://total-gbr.lubricantadvisor.com/eng
https://www.commaoil.com/passenger-vehicles
- x 1751
Re: Engine Coolant
Just don't mix types, brands, or go by colour (there are no colour standards).
If in doubt, check which one is recommended, and stick to that for all topping up.
Stick a label under-bonnet so it's clear what is in there.
- x 1942
Re: Engine Coolant
If you don't know what it's been filled with previously then be sure to flush it through thoroughly.
Then use an OAT glycol anti-freeze which will last longer than the old style phosphate based anti-freeze.
Steve Walsh
- x 516
Re: Engine Coolant
Changed mine recently, flushed it out and refilled with Glysantin G30 concentrate mixed with demineralised water, Bought it online from https://www.ato24.de/
EDC5
- x 130
Re: Engine Coolant
If you want Glysantin G30 then it can be had off ebay (in the UK) under the name Comma G30. £25 for 5 litres of concentrate:
https://www.ebay.co.uk/itm/381604388486
- x 1942
Re: Engine Coolant
What actually is Glysantin? Is it just a trade name? Is it a special type of OAT anti-freeze? I believe that there is G30 and G40 (perhaps more), what's the difference there?
- x 3566
Re: Engine Coolant
IIRC, it's made by BASF and used by many different manufacturers. Somewhere I've got the technical documents for it.
Andle
- x 4
Re: Engine Coolant
I don’t know what’s been in there already. I am the third owner of the car.
What’s the right way to do a thorough flush?
If I want to do it myself, is there a bolt or spout which can easily empty the coolant through - or will I have to unclip the radiator hose?
The spout route makes it a much cleaner quicker job.
Could someone help check to see if my cooling system has an easy way to extract the fluid please.
- x 6957
Re: Engine Coolant
See my illustrated post here: The procedure is exactly the same for your Picasso:
viewtopic.php?p=627831#p627831
Andle
- x 4
Re: Engine Coolant
Thank you for that GiveMeABreak.
Realistically - I don’t have access to any of that equipment.
The coolant system needs to be thoroughly flushed and cleaned out first of all remaining remnants - as I do not know what was in there before.
Once cleaned out - then I can think of filling with the final correct coolant.
To get this done right - I’m going to have to leave it to a pro?
Steve Walsh
- x 516
Re: Engine Coolant
My C5 has the same engine as Marc's link, I recently flushed and changed my coolant without any of the special tools,
Refilled with Glysantin G30
- x 3566
Re: Engine Coolant
The only thing you'd really need that would be 'non-standard' would be a method of making a funnel to fit tightly onto the neck of the expansion tank. You could get creative with Gaffer tape and a coke bottle - as long as you can (safely) give the expansion tank a raised head of water then that will do. The specialist tools make the job a lot easier, but it can still be done with basic tools.
To do a decent job of flushing the system, you really do need a hose and running water - making sure to catch the old antifreeze and dispose of it properly as it can be poisonous to some animals even in small doses.
