Hello,
I have Peugeot 308 T9 BlueHDI with EAT6. Since I bought the car, shifting to 3rd or 4th gear would be randomly a little harsh, you have a feeling like someone pushes you from behind when it does this. Yesterday I was browsing the Diagbox and I discovered two procedures under the Gearbox section:
- partial realignment of programmed values
- full realignment of programmed values
Both procedures shows that they are used when replacing gearbox ecu, gearbox, or both. So, my question, could this do any harm running on the car which didn't have anything replaced and is there a point in running those procedures, could running them help with shifting?
Just to mention, oil was changed in the gearbox, didn't make a difference.
EAT6 realignment
- x 1449
Re: EAT6 realignment
The intermittent nature of your problem is probably because the automatic tuning of transmission parameters is unable to converge on a set of parameters that works well under all conditions. It is possible that the transmission is trying to mask the symptoms of some internal hardware fault. I am not familiar enough t=with this particular transmission to know what that might be.
triggering the realignment procedures is probably not going to do any harm, but there may be some special instructions about how to drive the car to ensure that the procedure completes correctly.
- x 1056
Not sure what a EAT6 gearbox but if its a controlled manual gearbox like EGS or sensodrive then make sure you have another running car connected to the battery with jump leads while carrying out any re initialisation procedures, they can be quite hard on the battery & if the voltage drops too low the procedure will fail.
- x 1449
The EAT6 is an upgraded, more efficient version of the AM6, so is a "conventional" torque converter hydraulic transmission.
- x 1056
Ok ignore what i said about connecting another car with jump leads then.
mara-
- x 7
@xantia_v6
It would be very useful if anyone had the access to the Diagbox documentation and provide the information about those two procedures.
Lubo83
hello I'm new to the group,,:) I have the same problem with my 308 t9 GT 2.0 181hp there is a slight pulling or swelling between 3 speed and 4. I went to the dealer and he said there were no error codes but I replaced the box with another one and the same problem.
- x 6956
Torque steer will happen because it is Front Wheel Drive and the driveshafts are unequal lengths, despite measures to reduce this effect. It mostly happens in more highly torque-producing vehicles like diesels, but shouldn't be noticed under 'normal' driving conditions.
kalwap
hey guys! i have same issue after top gasket replacement and propably injectors damage right after caused by mechanics propably - the thing is - after gasket replacement that goes fine - car was not driving properly(weak power/torque) and gear shifting were totally harsh - after I replaced injectors in Peugeot I foxed the problem with power/torque but gear shifting are not going soft - its like manual from time to time have this feeling.. - I have tried other car with same gear/engine and its shifting perefctly - i belive there is some issue in between gearbox and engine aliggnment... how to fix it?
I have tried realignmenet thru diagbox (there is some procedure there) but it didnt happend. I cant belive that gearbox suddently got damaged or anything like that..
Please give me some clue guys <3
drayton11
First thing I would try is get the car hot & drop the fluid in the EAT6 box, you should get around 3L out, but the box holds 7. Other manufacturers specify changes around 60K, but Pug say it's sealed for life, dirty/low fluid will give harsh shifts, once you have changed it a few times tell the car via Diagbox it has new fluid, there are procedures on how to do it on this site, AM6 oil change I think. Make sure you get the correct fluid for your box & use a premium brand.kalwap wrote: 20 Mar 2023, 09:23 hey guys! i have same issue after top gasket replacement and propably injectors damage right after caused by mechanics propably - the thing is - after gasket replacement that goes fine - car was not driving properly(weak power/torque) and gear shifting were totally harsh - after I replaced injectors in Peugeot I foxed the problem with power/torque but gear shifting are not going soft - its like manual from time to time have this feeling.. - I have tried other car with same gear/engine and its shifting perefctly - i belive there is some issue in between gearbox and engine aliggnment... how to fix it?
JADED
- New User
What about a brand new car experiencing the same problem - kicks and jolts on upshifts or downshifts? I have less the 1 mile on odometer.drayton11 wrote: 21 Mar 2023, 11:06First thing I would try is get the car hot & drop the fluid in the EAT6 box, you should get around 3L out, but the box holds 7. Other manufacturers specify changes around 60K, but Pug say it's sealed for life, dirty/low fluid will give harsh shifts, once you have changed it a few times tell the car via Diagbox it has new fluid, there are procedures on how to do it on this site, AM6 oil change I think. Make sure you get the correct fluid for your box & use a premium brand.kalwap wrote: 20 Mar 2023, 09:23 hey guys! i have same issue after top gasket replacement and propably injectors damage right after caused by mechanics propably - the thing is - after gasket replacement that goes fine - car was not driving properly(weak power/torque) and gear shifting were totally harsh - after I replaced injectors in Peugeot I foxed the problem with power/torque but gear shifting are not going soft - its like manual from time to time have this feeling.. - I have tried other car with same gear/engine and its shifting perefctly - i belive there is some issue in between gearbox and engine aliggnment... how to fix it?
