New Instrument cluster
x 6954
Re: New Instrument cluster
The configuration part is pretty standard for all variations of instrument cluster - because as I already mentioned, the specific instrument panels are different for some engines and transmissions, so this assumes you have the correct one for the vehicle to start with.
So as far as configuration goes, the options are limited to Parking assistance, Current info display position, Stop / Start system, Maintenance, Oil Gauge, Controlled Suspension, Navigation Option, Cruise, Speed Limiter, Trip Computer, Volume and Distance units, and of course language...
C5-NON
Unread post by C5-NON »
****UPDATE*****
I got lucky and found a brand new 2015 part on eBay for £140. Fitted it today (was a bit fiddly), and va va voom! i have working Fuel and Speedo again! Magnifique! - only thing i need to do is change the language (default French) and km to miles in Diagbox, although i may leave in French for additional oh la la!. So there you go, your gauges can go faulty!, i had a look at the old unit on the circuit board, cant see any obvious failure, so i assume its the stepper motors.
Cheers for all your inputs!
x 3295
It could be worth finding replacement stepper motors and repairing the old unit, just in case.
x 6954
Nicely done. On the older MK I & IIs these were a common failure and simple replacement motors could be dropped in pretty easily. Some of the instruments on the X7 are digital and some must still use the motorised displays for the speedo and the like. Glad it's sorted
miruim
Unread post by miruim »
Hello to all
I would like to make a question.
I have the total orange cluster in my c5 x7, and i would like to change to a colour one.
It is plug and play?
If the colour one have lower km will assume the correct km from the BSI?
Regards to all
x 6954
Yes, whichever has the highest reading will become the permanent reading when connected.
