Grand Picasso won't start.. intank fuel pump?
venbo_
Unread post by venbo_ »
Hello everyone. My 2013 Grand Picasso 1.6 hdi stayed for about 6 months and yesterday I have tried but it won't start. At some point turning the engine to start it started and stopped. I have unplugged the fuel line coming from the tank and there is no fuel coming while attempting to start which means - sender(low pressure in-tank fuel pump) doesn't work. Tank half full with diesel. I have tried to find any info where is the sender located- is it in-tank or next to the tank, or at front (engine bay). The most frustrating part is - there's no access to the in-tank basket from inside the car (under the back seat) there is no any cover to open and to take it out. Can anyone please help me with some info where the low pressure pump is located on that model? VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks for your time and attention.
x 1055
Re: Grand Picasso won't start.. intank fuel pump?
Unread post by wheeler »
Does it definitely have a pump in the tank? If there is a hand primer under the bonnet there wont be a pump in the tank.
venbo_
Thank you. I am not sure- as I have read some technical information - looks like it's without in-tank pump. Yes - I found a primer on top of the fuel filter. Is it possible to check the VIN somewhere in internet to receive info about the fuel tank etc...? Thanks again.
x 1751
Yes - If you can post your VIN here (it will appear masked), we can post details/diagrams of the fuel system for the car.
You'll need to make a small donation to the forum to cover the costs of this, which will give you the ability to request further parts info (for any Citroen/Peugeot vehicle) during this year and next.
A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
venbo_
Thank you. I have just made a donation. Here is the VIN of my C4:
Thanks again for your help.
x 1751
Sorry for the delay.
Hope this is helpful...
C4 PICASSO ESTATE - LEISURE 1.6 HDI 115 (DV6C) Manual gearbox 6
Click to enlarge
No pump in the tank, just a pickup and level sensor.
Donation
Thanks for making the donation.
The minimum donation is £10, so if you could drop a little more into the pot, that would be appreciated.
Have posted the parts info this time, just so you're not held up!
venbo_
Thank you very much- will top up the donation. Thanks again.
x 1751
Brilliant. Thanks.
