X7 injector coding
- My Cars: Citroen c5 break
Renault trafic
X7 injector coding
Hi all and thanks for letting me join.,newbie here on the forum and with citroen so I hope I havent bought a pup! I need to change no1 cyl injector and was wondering if the new one will need recoding to ecu, I know some do and some do not but no idea on this car. The engine is the 1 6hdi. Thank-you.
- My Cars: Currently:
C5 X7 VTR + Satnav Hdi estate Silver
C5 X7 VTR + Hdi Estate 2008 Red
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1205
Re: X7 injector coding
Hi and welcome to the forum.
I haven't had an injector problem with mine yet, they generally seem to be a very reliable engine, the previous 8 valve 2.0. didn't need the injectors programming but don't know about this one. I sure someone will be along shortly who does.
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5722
You'll need to provide your VIN (automatically masked) so we know exactly which engine and system you have fitted, but either of the 2 1.6 HDi engines need new injectors to be coded:Broken-down wrote: ↑29 May 2020, 11:20 Hi all and thanks for letting me join.,newbie here on the forum and with citroen so I hope I havent bought a pup! I need to change no1 cyl injector and was wondering if the new one will need recoding to ecu, I know some do and some do not but no idea on this car. The engine is the 1 6hdi. Thank-you.
DV6C Engines: note the injector classification (6 characters).
DV6TED4 Engines: note the injector classification (8 / 9 characters).
When replacing the injectors on both these engines, they must be coded using a diagnostic tool.
Renault trafic
Thanks Marc
Would I be right in thinking the tool isn't a standard obd2 type.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
The diagnostic port is a standard OBDII port. You can connect other compliant diagnostic equipment - but these vary in their capabilities of course.
The bespoke diagnostic software used with an Actia VCI Clone for PSA cars is Diagbox / Lexia / PP2000 depending on year, but in either case all are included and encapsulated within the Diagbox software.
Renault trafic
Thank-you
