Hi.
VIN VF7**************[VIN obfuscated, can be read by forum staff].
Many thanks
Eolys. What type do I need and what is the tank capacity?
Markta
Markta
Re: Eolys. What type do I need and what is the tank capacity?
I’m guessing only mods will be able to assist as VIN number not visible.
Any help greatfully received
- x 3296
Correct. The forum software automatically obscures the VIN for security reasons, so only Forum staff can read it (and so can you when you edit that particular post with the VIN).
- x 6945
Your Build date is 11033, so that means your C4 takes Eolys 176. As supplies of this have probably run out the replacement is Infineum F7995, which are the only 2 types of additive that can be mixed. So look for Infineum F7995. Your tank should have the green click fit connectors, but regardless, this is the additive you need.Markta wrote: 18 May 2020, 21:45 I’m guessing only mods will be able to assist as VIN number not visible.
Markta
Cheers Marc as always. You’ve been extremely helpful during the time I’ve been on here
- x 6945
No worries - click on the table above to magnify it and you'll see walker equivalent products against the OEM parts references.
