So I just recently welded my AX 10E 1987 and after this I put my headlights back and one headlight is dimmed the other will burn?
Is there no relay between it?
Anyone knows this?
Citroen AX 87 dimmed L headlight
jsp
- x 12
- x 1459
Re: Citroen AX 87 dimmed L headlight
This is almost certainly a disconnected earth wire, or a corroded earthing point for the headlight.
jsp
- x 12
Should I pull an extra wire earth then to the headlights?
I was rethinking redoing the whole light system.
My Citroens update:
http://www.frenchcarforum.co.uk/forum/v ... 14&t=50070
- x 1459
You could just try running a new ground wire to the affected headlamp as a temporary repair.
Your wiring diagram is a bit confusing and as drawn, probably would not work.
Note the pin numbering on Bosch relays:
It is probably just as good to fit a single pair of relays that feed both headlights, doubling up on the relays won't improve performance if suitable gauge wiring is used.
- x 1746
Agree with that. Only two relays needed: one for main beam, one for dipped.
This takes the electrical strain off the lighting/dip switch, and can keep cable runs from battery (fuse) to headlights short.
jsp
- x 12
ok what is the pinout of a H4 lamp?
are the R2 and H4 pinout the same?
My Citroens update:
- x 1746
jsp
- x 12
jsp
- x 12
ok just got sorted, broken dipped beam wire. Will rewire all with relays.
My Citroens update:
- x 1746
A missing earth/ground connection on an H4 puts both filaments in series, and finding a path back through the other headlight, so the faulty one appears exceptionally dim!
Missing earths on rear light clusters produce all sorts of fun, including indicator and tail-light bulbs dimming and glowing every time the brakes or indicators are used. Car manufacturers still seem to struggle with bodywork grounding. Hardly rocket-science, but it does involve Beans.
jsp
- x 12
Thanks Exec, seems only German/French car struggle to do an extra earth on the rear lights.white exec wrote: 16 May 2020, 08:28 A missing earth/ground connection on an H4 puts both filaments in series, and finding a path back through the other headlight, so the faulty one appears exceptionally dim!
Got it fixed now, will rewire all with relays.
My Citroens update:
